2007-2010 Silverado Dynatech MuscleMAXX headers by MAK Performance
dynatech-supermaxx-headers-for-gm-4-8l-5-3l-6-0l-6-2l-3
These Dynatech MuscleMAXX headers feature a 2-step primary tube design with long tubes for increased horsepower and torque. They also have 3/8 in. CNC-machined flanges for a long-lasting leakproof seal and are constructed from mandrel-bent, 16-gauge mild steel tubing.
Dynatech MuscleMAXX headers are available with a high-temperature silver ceramic coating or high-temperature black paint and include gaskets and header bolts. The headers use a 3 in. collector with a 4-bolt leak-free flange, as well as an available ball and socket self-aligning reducer cone. Drag race versions feature a slip-fit connection and include weld-on “U”-style tabs. Add some horsepower to your vehicle with these Dynatech MuscleMAXX headers.
Unless otherwise noted, these headers are designed to fit the vehicle as it came from the manufacturer. This includes components like cylinder heads, chassis, steering, motor mounts, body mounts and bushings, etc. If your vehicle is using aftermarket components, parts from other applications, or custom altered parts, then it is the installer’s responsibility to verify fitment.
Click here for Chevrolet LED Signs
Post a Comment
