Results 1 to 2 of 2
02 crew-cab door lock problem
This is a discussion on 02 crew-cab door lock problem within the Audio/Video Electronics forums, part of the General Discussion category; I've had my 02 crew-cab for about 2.5 years and originally put in a Sidewinder remote start/alarm into it. About ...
    eBay-aholic x6369x's Avatar
    Jan 2002
    Sacramento, CA
    I've had my 02 crew-cab for about 2.5 years and originally put in a Sidewinder remote start/alarm into it. About 3 months ago, I upgraded to the Viper 791XV 2-way remote start/alarm and it's been working perfectly.
    I noticed this morning that only the driver's door will lock/unlock via the Viper remote. Also, only the driver's door will lock/unlock via either the driver and passenger door switches. The 3 other door locks (passenger front and both rear doors) have stopped working for some reason.
    I've had no problems w/ the locks in over 2.5 years, and originally installed the alarm per a DEI tech sheet. I connected the positive door lock outputs of the alarm directly to the lt. blue (lock) and white (unlock) at the BCM. My thinking is that if one of the alarm wires came loose, that the door lock would stop functioning all together, but still work with the factory switches.
    I'll probably look at it tonight, but I was wondering if anyone had any ideas on what to check.
    Thanks in advance.
    Jan 2002
    Sacramento, CA
    ***** FIXED *****
    OK it was a blown LOCK fuse in the fuse panel on the driver's side of the dash.
