Results 1 to 4 of 4
JL Audio Stealth Box mounting question
This is a discussion on JL Audio Stealth Box mounting question within the Audio/Video Electronics forums, part of the General Discussion category; Bought a used 1 for the 96 Yukon and I need help on mounting it. I'm thinking I didn't get ...
    Shrt Rnd Lw 2 D Ground
    Nov 2002
    ontario, canada
    Bought a used 1 for the 96 Yukon and I need help on mounting it. I'm thinking I didn't get the brackets needed for installing it, but I'm not sure what it needs to mount in
    thanks
    Gerry
    00 Silverado Z71 LT EXT Wester's 93, Dynomax, Poweraid, K&N, LS1 fans, Corvette Servo, Trans-go
    96 Yukon 4 x 4, 4dr, SLT Wester's 93, UPD, MSD, Magnaflow, Casper's, LT1 fans, Corvette Servo, Trans-go **S O L D**
    Registered User Litljay's Avatar
    Mar 2002
    Central Cali
    Is it the center console one?
    Mine was simply mounted by drilling holes through the tranny hump and bolted through there. There should be two screw holes on the bottom of the box.
    Nov 2002
    ontario, canada
    yes it's the console one, was really hoping that I was missing something. unsure if I want to drill through the floor.
    How does it sound?
    Mar 2002
    Central Cali
    It is MUCH better than stock and gives much more "up front" bass than sticking a box in the back. But it is limited. You are only running 1 10" sub, so don't expect miracles.
