Results 1 to 19 of 19
Need help figuring out a resistor value
This is a discussion on Need help figuring out a resistor value within the Audio/Video Electronics forums, part of the General Discussion category; Ok, so I have something that runs off of 5 Volts, that I want to use in the car, what ...
    SPL NUT!!! idbl_Fanatic's Avatar
    Jul 2002
    Stockton, Ca
    Ok, so I have something that runs off of 5 Volts, that I want to use in the car, what value should I use? I was thinking 70 Ohm. But not sure
    Need more power? UP YOURS!! with Excessive Amperage!
    Registered User Charles U Farley's Avatar
    Jun 2003
    AL
    what are you doing? is this replacing another resistor? are you making something? how many amps are you/do you want to draw?
    Jul 2002
    Stockton, Ca
    I am adding a volt meter, and it needs 5 Volts to turn on, instead or 12, no clue on the amps, but I am sure it's not much
    Jun 2003
    AL
    whats the specs on the volt meter (i.e. internal resistance). im trying to think of what your doing looks like on paper.
    Jul 2002
    Stockton, Ca
    05 GTO upgrade.
    Apr 2004
    Texas
    What color are the bands on the resistor?
    1991 C1500 Ext. Scrapped. I still have the engine, tranny and Detroit tru-trac.
    2005 GTO LS2 with full Pedders track II suspension. StreetsweeperHT cam with Kooks exhaust. Tuned.
    Jun 2003
    AL
    ok, im a tard,
    got to thinking, the voltmeter will have a high internal resistance, i.e. megaohms, and is otherwise irrelevent. whats the specs on what you want it to measure?
    Jul 2002
    Stockton, Ca
    ok, im a tard,
    I am going to put that on the + and - wire at the amps, so that I can monitor the voltage drop as I compete, my amps have a tendancy to catch fire under 10.5 Volts
    Jun 2003
    AL
    ok, hope this is what you wanted.
    Jul 2002
    Stockton, Ca
    eBay-aholic x6369x's Avatar
    Jan 2002
    Sacramento, CA
    Dood, go to Radio Shack and get a variable resistance pot (potentiometer). Wire it up, then adjust it till it reads 5 volts. Then measure the resistance.
    Jul 2002
    Stockton, Ca
    That's too easy
    Jun 2003
    AL
    yeah,
    for some reason, i earlier thought that you wanted to incorporate this as part of your amp, in the same circuit. take that drawing i gave you and instead of the second resistor, put in a 5v zener diode.
    http://hyperphysics.phy-astr.gsu.edu...enereg.html#c1
    this page should tell you everything you need
    Insecure fat kid DemoN's Avatar
    Jan 2002
    San Antonio, TX
    Rick...you just get one instead of four?
    you have a distribution block? you going to put it on the "IN" side or what?
    i'm going to order some, but i didn't know if i should put a voltage meter on each amp or just at the dist. block. so i'm wondering how you were going to wire yours up.
    wait...you have all your amps synced right? so they're all daisy chaining off each other.
    Jul 2002
    Stockton, Ca
    Not anymore, they are different amps now, I am just wiring it in to the distro block, so I can see what the drop is there, I also put a suction cup on the back of it, so that I can take and stick it to the window on the outside when I am competing.
    Oh yeah, and a 100 Ohm resistor worked just fine!
    Here are some pics.
    Jan 2002
    San Antonio, TX
    got a pic of it working yet?
    BTW: thanks...you told me exactly what i wanted to hear :LOL:
    hey...that's the 0-20V right?
  17. #17
    Jul 2002
    Stockton, Ca
    I do now...........here they are, and yes it was the 0-20volt one
    it is only at 14.02 Volts, cause the lights were on, and the 12.64 and .65 were with the engine off
  18. #18
    05 GTO upgrade.
    Apr 2004
    Texas
    Cool!!!! You should do a write up on it in the Tech forum.
  19. #19
    Jan 2002
    Sacramento, CA
    Originally posted by idbl_Fanatic
    MAN that engine compartment is dirty. Good think you compete in SPL and not IASCA SQ. :kidding:
