Results 1 to 18 of 18
almost ready
This is a discussion on almost ready within the Audio/Video Electronics forums, part of the General Discussion category; made my seat lift blocks today, and have the plans for the box all done. these worked like a charm ...
    Feb 2003
    almost ready
    the box... 2.5 cu.ft. tuned to 32Hz
    I'm going with two RE SE10's. the box is built exactly to what's recommended. power will come from my Arc 1500dr.
    It's gonna be one more week b4 I order the subs and start working on the box. I can't wait.
    comments/suggestions?
    Insecure fat kid DemoN's Avatar
    Jan 2002
    San Antonio, TX
    Re: almost ready
    Originally posted by belmontrider
    suggestions?
    i like the design and i like the way up you laid it out. 1 suggestion..cut a cross section thru the aera over the hump...if you're going to draft it out, leave nothing to guess
    Feb 2003
    i did, just didn't post that pic.
    Jan 2002
    San Antonio, TX
    just lookin out.
    bama wheeler
    Jul 2003
    fairhope
    the blocks and the box design are both very nice. good choice on subs and amp too
    eBay-aholic x6369x's Avatar
    Jan 2002
    Sacramento, CA
    Looks good. What did you use to make the drawings?
    100% Roots Rocka DSZ71's Avatar
    Jan 2003
    Sittin next to the Govenator
    Nice. What did you use for those blocks? It looks like some square tubing with one end cut off and then a piece of flatbar for gusseting support. I didnt know you knew how to weld.
    Just a quick question about your sub choice, the reason you didnt get the IDs was only because of price?? I would have liked to see(actually hear) them in that box design.
    **My Little Roots Rocka**
    Feb 2003
    some freeware program called CadStd. I lost the serial number for the copy of AutoCAD I have.
    the blocks are just 1 1/2" square tubing. I cut two slits down the sides and bent the middle part in, then tacked it. Then just tacked the bolts in too.
    I had four different subs in mind, the IDs, CM3s, Ed k's, and the SE's. I finally decided to just go w/ two subs and these seemed like they suited me best. And $165 shipped/each isn't bad. It would've been over 5 bills to get the four IDs.
    Jun 2004
    Nantucket, MA
    Very nice job....nice to see the RE's making a stop here.
    I am just about to do a XXX 12 in my tahoe....3 cubes tuned to 30hrz....tarantula powered.
    04 Tahoe Z71
    Suspensionmaxx Keys and Spacers
    UPD Intake
    Tuned by SlowHawk Performance
    Pioneer AVH-P7800DVD
    Pioneer ts c720prs (Front and Rear)
    Zapco C2K 2.5X
    Zapco C2K 9.0XD
    RE XXX 12'(Sub)
    Knuconcepts Wires
    Excessive Amperage 200 amp alt
    Jan 2003
    Right I understand now. Thats actually a smart design because you have more strength with the sides bent inwards. Cool beans mane
    Jan 2002
    Sacramento, CA
    Re: almost ready
    You need to start mass producing these and selling them. I'm sure a bunch of members here would scoop em up.
    Feb 2002
    Tulsa
    Re: Re: almost ready
    IBthumpin used to make them too.
    Mar 2003
    cincy
    you won't be disappointed with the se's. I'm running 4 10's in my truck and they slam pretty hard.
    1999 Chevy 1500 (OBS), 4/6 djm drop, 20" Intro Vista 5's, Alpine CDA-9835, Alumapro ALC 5.2, Rockford Fosgate Punch 250.2,450.2, (4) 15" Incriminator Audio DP's, (4) Orion 2500d's
    2009 Silverado, Rough Country leveling kit, 10k H.I.D.'s
    Jan 2003
    What about legalities? What happens if one of them or both fails in an accident, and someone gets hurt or dies? I'd shy away from that only because of the liability issues.
    Registered User t0yrunner's Avatar
    Jul 2004
    Mississippi
    please post pics of this finished. I really want to see how those seat lifts work out. I was looking at doing that in my NBS.
    t0yrunner
    Jan 2003
    Hey Doug, did you also make the extension pieces for the top part of the seats?
  17. #17
    Feb 2003
    no, i didn't have to. It works perfect...when the seat is down in the regular position, the back is secured w/ the hooks. but when you pull that strap and fold the bottom up, the seat back rises a little and it's just enough for the back of the seat to clear the hooks and the back folds down then. it's great for accessing the amps.
  18. #18
    Feb 2003
    I added more port area after realizing they were a little small, which in turn lengthened the ports, so my new ports will look like this. Still 32Hz...
