Results 1 to 3 of 3
Satellite Radio Noise
This is a discussion on Satellite Radio Noise within the Audio/Video Electronics forums, part of the General Discussion category; In my 2003 (new) GMC truck I hear a static noise in the Sirius(sp) satellite radio speaker located just above ...
    Jul 2003
    Houston, Texas
    In my 2003 (new) GMC truck I hear a static noise in the Sirius(sp) satellite radio speaker located just above the drivers head. When I turn the motor off, the static noise slowly goes down sounding like energy draining out from the speaker. I am not a satellite subscriber and this static noise is bothering me. Any suggestions as to what is causing this?
    Chevy junkie
    Oct 2002
    Lubbock, TX
    Re: Satellite Radio Noise
    Quote Originally Posted by fmdog44
    What sirius speaker are you talking about? If you are not a subscriber, then why did you have sirius installed?
    Do you have automatic climate control and you are referring to the little vent thing about the driver's head? If so, then that is not a speaker, it is a small fan that senses the temp for the climate control. They are notorious for being noisy and sometimes a new sensor will cure the noise. Hope this helps
    2006 2500 Burb DURAMAX 4x4 LT 4" exhaust
    Jul 2003
    Houston, Texas
    DMAXMAN- thanks a ton.
