Results 1 to 19 of 19
almost done, need suggestions
This is a discussion on almost done, need suggestions within the Audio/Video Electronics forums, part of the General Discussion category; i'm almost done covering my box. i was gonna just use grey carpet to cover the sides and hide the ...
    Feb 2003
    i was gonna just use grey carpet to cover the sides and hide the vinyl overlap. any better ideas for finishing the sides? any other ideas to keep it in place besides the tiedowns? it was sliding all over the place without them.
    and how should i finish it around the ports so it doesn't look so ghetto?
    typical custom user title OKLAGMCRUISER's Avatar
    Feb 2003
    Kiefer, OK
    Re: almost done, need suggestions
    To mount the box..remove the subs and screw/bolt the box down to the floor.
    Ad for the ports....I think it need the vinyl taken into the box or something along that line.
    Otherwise, the box looks well built. The sides...I have no clue...
    Feb 2003
    i thought about bolting it in but dont really want to.
    Poor college student Exalted512's Avatar
    Mar 2004
    College Station, Texas
    try making a strap and bolting it to your seat belt bolts to make it stay in place
    i wouldve done like he said and vinyled the port too...or at least spray paint it with a gloss black
    -Cody
    100% Roots Rocka DSZ71's Avatar
    Jan 2003
    Sittin next to the Govenator
    Quote Originally Posted by Exalted512
    -Cody
    WERD UP G-NUTZ...since you know how to weld, either get some flatbar or angle iron and see if you could make a few brackets that fasten to the existing bolts (like your seat belts or jack and accessories).
    BTW homeslice...make sure to post up some more pics of that box and its progress.
    **My Little Roots Rocka**
    Not using my RE8's slaterbj's Avatar
    Feb 2004
    Grand Rapids, Mi
    For finishing the ports what about getting some aluminum angle, like .5"x.5",frame it in and paint it black. I know that it will kill the radius on the exit of the port but it would look pretty good.
    2002 Chevy 2500HD 6.0L Hypertech, Flowmaster 40 series, BFG's, K&N, Eclipse 8443, JL Audio300/2 - 500/1, CDT CL-61, 2- Alpine Type-R 10's, and Lots of Second Skin!
    eBay-aholic x6369x's Avatar
    Jan 2002
    Sacramento, CA
    For the sides, cover some 1/8" fiberboard w/ the vinyl and attach it to the sides w/ velcro or silicone. You're going to see a seam where the side meets the box, but it'll look cleaner.
    Feb 2003
    Quote Originally Posted by x6369x
    that's one idea i had. I think I have enough vinyl left.
    Mar 2004
    where did you get your vinyl from?
    -Cody
    Feb 2003
    local fabric store, not a chain or online.
    Jan 2003
    Hanc0ck Fabrics here in Tucson has some. Pretty close color match as well. Not sure if there is a Hanc0ck in College Station. (or there might be a "hand-c0ck" when you go to sleep Cody LOL)
    Mar 2004
    :LOL:
    too bad the olympics hasnt picked up pocket pool yet...im sure youd take the gold!
    -Cody
    most unique username
    Oct 2001
    Bainbridge, NY
    Quote Originally Posted by slaterbj
    to build on this idea, use what they call "corner guard" - its used to protect the corners of walls. Its clear and has a double stick tape applied to the backside. Its "L" shaped and is about 3/4" wide comes in 4ft lengths. Miter the corners and stick it down, after painting it of course.
    Its what I used to dress the edges of my amp rack under the rear seat - actually it hides the staples that secure the fabric to the frame of the amp rack.
    Jan 2003
    Take it to San Luis and have them upholster it. I had my rear Jeep seat done in Mexico and for the $30 they did the entire thing and it was bad-ass. They should be able to help you out. Just take out the subs and chit mane. Have them "fold and tuck" it...or some Diamond Tweed!
    Feb 2004
    Grand Rapids, Mi
    Quote Originally Posted by DSZ71
    Sweet Idea!
    Unfortunately Canada is closer to me then Mexico.
    tuckin' 22's 8.1 HD's Avatar
    Nov 2001
    CT
    As far as the sides go....some swirled aluminum or some diamond plate cut to the size of the box and then screwed on.
  17. #17
    Jan 2002
    Sacramento, CA
    Quote Originally Posted by 8.1 HD
    That's also another good idea. Just depends on the "theme" of his truck.
  18. #18
    Feb 2003
    for now
  19. #19
    Jan 2002
    Sacramento, CA
    Carpeted sides? Ran outta vinyl?
    Looks good tho
