Results 1 to 8 of 8
Subwoofer setup...ohms and stuff
This is a discussion on Subwoofer setup...ohms and stuff within the Audio/Video Electronics forums, part of the General Discussion category; Will this setup be giving the amp a 2 ohm load? I just want to make sure before I go ...
    Hit 'em Low Buginajar's Avatar
    Feb 2002
    Irving, TX
    Will this setup be giving the amp a 2 ohm load? I just want to make sure before I go running all the wires.
    | 2k RCSB | DJM 4/6 | SS Bumper Cover w/ Speed Grille Inserts | Flowmaster 3.5" 1-Chamber | Passport 8500 | Alpine CDA-9833 | Hifonics BX1500D | 2-10" Alpine Type-R Subs | Sirius Satellite Tuner |
    Current GM Owner sbc44's Avatar
    Nov 2002
    Thomasville, GA
    Re: Subwoofer setup...ohms and stuff
    Isn't the BX1500D a mono amp? That illustration looks like its 2 channel. But anyway, going by that drawing if the voice coils are each 2 ohm and connected in parallel connected to a 2 channel amp it will be 4 ohms on each channel.
    04 Tahoe LT
    Feb 2002
    Irving, TX
    Quote Originally Posted by sbc44
    Its a monoblock, however there are two pos and two neg connections on the outside
    Those connections are parralleled inside.
    Nov 2002
    Thomasville, GA
    Quote Originally Posted by Buginajar
    haha my bad, my amp is the same way i should have known. Are the voice coils 2ohm?
    04 Tahoe LT
    Feb 2002
    Irving, TX
    Yes each voice coil is 2 ohms.
    Nov 2002
    Thomasville, GA
    Yep looks like it will be a 2 ohm load then
    04 Tahoe LT
    most unique username
    Oct 2001
    Bainbridge, NY
    connected in SERIES
    parallel divides, series adds
    Nov 2002
    Thomasville, GA
    Quote Originally Posted by ibthumpin
    connected in SERIES
    hehe i was thinking series when i wrote that. DOH!
    04 Tahoe LT
