Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Rear speaker install, 93 GMC Ext Cab
This is a discussion on Rear speaker install, 93 GMC Ext Cab within the Audio/Video Electronics forums, part of the General Discussion category; I tried doing a search but couldnt really come up with much. I recently installed new 4x6's in the dash ...
    Member RTCamaroSS's Avatar
    Jan 2004
    Fremont, Ca
    I tried doing a search but couldnt really come up with much. I recently installed new 4x6's in the dash of my 93 Sierra Ext Cab pickup, and would like to also install a new set of 4x6's in the rear panels (stockers suck!). My local circuit city wouldnt even touch the install... im told its really difficult and the panels often break. Does anyone have a step by step install guide? with pictures? :) I dont mind doing it myself, seeing as how i need to run new speaker wire up to those speakers anyway for my 4 channel amp. While im asking about those speakers... how hard is it to run new wire to the front speakers as well?
    Current vehicles:
    08 Lexus IS250 - FSport.
    10 Toyota Sienna Limited - Wife's.
    96 GMC Sierra Z71 - Lift, Nav, Etc.
    93 Mazda RX7 - LS1/T56 Project
    Sold Vehicles:
    93 GMC Sierra Z71 - Lift, Etc.
    87 Chevy V10 - Lift, Stereo, Etc.
    99 Camaro SS - 600+rwhp, low 10's.
    98 Lexus GS400 - Lots of mods.
    Poor college student Exalted512's Avatar
    Mar 2004
    College Station, Texas
    Re: Rear speaker install, 93 GMC Ext Cab
    if you order from crutchfield, they send you a guide specific to your vehicle that will tell you everything you need to know
    -Cody
    04 GMC
    system in the works:
    Jan 2004
    Fremont, Ca
    i got my speakers for about half the price of crutchfield.. overpriced.. dont suppose anyone has those instructions eh?
    Current vehicles:
    Sold Vehicles:
    parrot on the bandwagon 95stroked1500's Avatar
    Nov 2003
    lala land
    take the back seat out, take the seat belts out, take the panels off. the rear center panel needs to be lifted out at the bottom and then up to release the top. if it has what i'm thinking of. you'll just have to make you own instructions as you go along. my 2 cents, if you're doing all that work to get in there, you might as well do a little and put 6 1/2's. some like 6x9. go buy a cheap air hack saw from harbor freight, about $35. take you about 5 min to do both sides.
    p.s.- i hate harbor freight, but for a non professional, that would do the trick just fine. personally, i'm by snap on.
    Jan 2004
    Fremont, Ca
    Quote Originally Posted by 95stroked1500
    sadly, so am i... you should see my bill with my dealer right now
    ill look into cutting and hacking up the rear... although i didnt really want to, im going to have 2 12's to make up the bass... and a 4 channel 4x50watt amp to support the 4 4x6's...
    Current vehicles:
    Sold Vehicles:
    Nov 2003
    lala land
    the diff in sound from 80 hz - 150 hz between a 4x6 and a 6 1/2 is worth the hack. which you really don't want to play your 12's up that high.
    my snap on bill........could just about be making vehicle payments. but you know how it is, once you start using a good professional tool, even craftsman seem to suck. i need to just start mailing my payments in. i'll get my bill knocked down and then the next couple times, i'll walk off the truck with more in tools than i just paid on my bill. that's ok, my dealer has been talking to me about doing a system in his boat. then it will be my turn to do the !
    Jan 2004
    Fremont, Ca
    hmm.. i happen to have a pair of polk 4x6's and a pair of polk 6 1/2's... they match. i was just going to put the 4x6's in the rear... now you got me thinkin. maybe i should put the polk 4x6's in the dash (replacing the existing kenwood 4x6's), and cut to fit the polk 6 1/2's in the rear.... that should sound decent being pushed by a sony 4x50watt amp (i know, not the best quality). i have a jvc kd-ar5000 deck powering it all. think that'll work out good?
    Current vehicles:
    Sold Vehicles:
    Nov 2003
    lala land
    i have to agree on your comment about the amp, but yes i think that will work great.
    Jan 2004
    Fremont, Ca
    yea, the amp was cheap, so i picked it up. i figured i was better off with 50x4 rms than what the deck puts out, 18x4 rms....
    how much work is it (time wise) to rip out the rear seat, belts, panels and such?
    Current vehicles:
    Sold Vehicles:
    Nov 2003
    lala land
    depending on how fast you are and if you have help, 1/2 to a whole day from start to finish. if you haven't ever done it before, i would plan on the whole day. because you are going to be a little careful not to break the panels and give for error in case "if it can go wrong" happens to you. 4-8 hours. but then again, my time frame can be off because i always get side tracked doing 10 other things in the process of any project. so most likely you can have it done in 4 hours or so, wiring in your amp will be extra.
    Mar 2004
    in all honesty...you should EXPECT to break 1 or 2 clips. ive broken about 7 total ripping my truck apart about 5 or 6 different times
    -Cody
    04 GMC
    www. .ca Beaver Customs's Avatar
    Jan 2004
    Hamilton, Ontario
    I'm going through the same thing with my '92. I would rather install 2 6x9's or 2 61/2's to balance out the mids in the cab anyways. The 6x9 mounting area will open up enough space to remove the old 4x6 without removing the seat, the interior panels top and bottom, etc.
    Nov 2003
    lala land
    are talking about cutting your panels instead of mounting the speakers underneath them?
    Jan 2004
    Hamilton, Ontario
    I mean to cut out an oval in front of the 6x9's, install the 6x9 and then cover it with the supplied grille.
    Jan 2004
    Fremont, Ca
    Soooooo glad i took your advice and put in 6 1/2's in the rear. I finished the install last night... took about 5 hours to put new speakers, deck, 2 amps, and 2 subs in... running all new wire to all 4 speakers. Man, this truck rocks now... ive never been so happy with a stereo system, using sub-par equipment... lol. Thanks again guys!!!
    Current vehicles:
    Sold Vehicles:
    Nov 2003
    lala land
    congrats, being happy with what you've done/got is the main basis of it all.
  17. #17
    Mar 2004
    glad you liked everything!!!
    -Cody
    04 GMC
  18. #18
    Jan 2004
    Fremont, Ca
    Ya know.. i hear a lot of bad things about Sony amps... but this setup sounds awesome... its a 4x50watt rms amp, pushing polk 4x6's in frony and polk 6 1/2's in the rear. And it sounds fantastic. I think the 5 volt pre-outs on the deck help that... i have a high pass filter on the 4 speakers. The mono-channel sony amp for the 2 sony 12's doesnt do too bad either. I decided to use a capacitor just so i didnt dim my headlights... i wasnt looking for massive base, i dont listen to rap. It sounds awesome accompanying country or rock though.... again, im super happy with it all. Any anyone replacing rear speakers in one of these trucks sound seriously consider 6 1/2's... it only took 5 minutes to make them fit. Thanks again guys.
    Current vehicles:
    Sold Vehicles:
  19. #19
    Registered User RatAttack's Avatar
    Nov 2004
    Rolla, Mo.
    lol damnit....I had all my panels out and a set of Alpine 6 1/2's held up to the hole an thought nahhhh it probably won't fit under the panel afterward so I went and bought a set of 4x6's and put it back together........this makes me unhappy lol
  20. #20
    Member # 10583 Ross's Avatar
    Dec 2003
    San Antonio
    How much rear panel cutting was required to fit the 6.5" speakers? I guess there's enough metal left to secure the speakers well? I am thinking of replacing all 4 of my speakers with some 6.5" Polk db's.
    1996 GMC Sierra RCSB
    4.3L V6 - 4L60E - 15" stock aluminums - 3.42s - slow weekend warrior
    2004 Chevy Tahoe LT
    5.3L V8 - 4L60E - 17" stock aluminums - 3.73s - less slow daily driver
