Your gonna amp the stock speakers?![]()
This is a discussion on how to get wires to amp to speaker..? NBS within the Audio/Video Electronics forums, part of the General Discussion category; Ok i got the amp in the backseat of my extended cab. Im still using the stock speakers. Any ideas ...
Ok i got the amp in the backseat of my extended cab. Im still using the stock speakers. Any ideas how to wire the speakers to the amp?
Chevy 2001 z71 1500 5.3, 4.56, Flowmaster, K&N Generation II Air Intake Kit and a Tune by JESSEBUBB
6inch Procomp /3inch PA bodylift / Micky Tompson 16x10 / 37x13x16 Boggers
Yea i know.. i decided to not amp the speakers till i get new ones and just amp my sub for now. But when i do get new ones how would i do this?
run the wires from the amp under the carpet, take off the plastic piece you step on and run the wires all the way up by the front door. Take off the kickpanels and doorpanels and you will see that u have to snake the wires through the black rubber hose connecting the door to the frame. This is the hard part lol. I found the easiest way to do this was to unsnap them so the hose is loose and tape the speaker wire to a stiffer piece of wire and try to snake it through and finally your wires are in the front doors.
Hope this helps dont know how much sense it made lol
Run the wires up to the dash, and to the harness and splice them in there?This is how ive done it before.
2000 Escarado,4.8 5 speed, Deville Tail Lights,Shaved everything.,Kp Canti 4 link,EDC,16 Gallons.TR224 Cam, Lpp Long tubes.
2006 2500HD Duramax 4x4,CCSB,PPE HOT +2 ET,4" turbo back straight piped!
Originally Posted by airhead
:werd: RCAs from deck to amp, wires from amp to speakers.
Thanks for deleting absolutely everything from my sig. You asked me to do it, I didnt comply at 4am, so my entire sig was deleted...cool.
