Results 1 to 2 of 2
OBS Suburban re-amp install.
This is a discussion on OBS Suburban re-amp install. within the Audio/Video Electronics forums, part of the General Discussion category; I need to know where to drill through the firewall on the passenger side to get to my battery. I ...
    BeaterBurban
    Jan 2004
    Orange park florida
    I need to know where to drill through the firewall on the passenger side to get to my battery. I had my system hooked up through the drivers side, but I got some free 2 guage and will be running it from my battery to a distrubution block. I don't have enough to go drivers side and I can't find a legitimate area to poke a hole without being afraid of damage.
    1995 Suburban 4x4
    Flowmaster Super 40
    2 infinity 12's powered by hifonics amp.
    TBI 350.... soon to be modded.
    4.10 gears
    Did you just see that? Blue94's Avatar
    Feb 2005
    Elizabeth City NC
    Re: OBS Suburban re-amp install.
    there is a spot under the ac condenser that has a rubber grommet you can take out and cut a hole in it the run the wire through. if you look under the dash on the pass side you will see the grommet and be able to pull it out. the grommet is just a hole, nothin runs through it, atleast on my truck that is.
    2005 Joe Gibbs Silverado #0396
    1992 Integra GS
    2 1975 Camaro's
