Results 1 to 10 of 10
Will this box fit?
This is a discussion on Will this box fit? within the Audio/Video Electronics forums, part of the General Discussion category; I have a 2003 Regular Cab Silverado. The box I am looking at is 57"W x 14"H x 5.5"TD x ...
    Feb 2005
    Louisiana
    Will this box fit?
    I have a 2003 Regular Cab Silverado. The box I am looking at is 57"W x 14"H x 5.5"TD x 8.5"BD. I am way from home for the next couple months, so I can't actually measure it myself. The only measurement I am not sure about is the 57" width.
    Thanks for your help.
    Casey
    Feb 2005
    Louisiana
    Re: Will this box fit?
    bump.....
    Mar 2005
    Ironton, Ohio
    Quote Originally Posted by caseyq
    Casey
    I think the max width is 54" but I will check later today and let you know.
    Registered User 99silveradoguy's Avatar
    Nov 2004
    usa
    the box I have in my truck now is 54" long and theres gottabe at least 2-3" on ech side left over, Your gonna have to take out your middle seat to fit it in though
    - 99 Silverado - retired to spare vehicle
    Black headlights/turnsignals/taillights- 6K HID Low beams, back on stock rims. current project/DD 99 jeep TJ
    Feb 2005
    Louisiana
    Thanks for the replies. Could you double check just to make sure.
    Casey
    Nov 2004
    usa
    trust me , it will fit fine, the 54" one I have has a good 3" on both sides , maybe more before it hits the plastic trim panels (even if it got anywhere near the plastic trimpanels, theres another 2-3" each side past that too)
    compared to mine, the 57" is only 1.5" longer on each side
    Youll just need to remove the middle seat if you have it, the box wont make the corner trying to slide it in from the side, and wont fit from the top trying to get it in, it will fit fine with the middle seat after its in place
    Feb 2005
    Louisiana
    I have a center console that folds down. Thanks for the knowledge. I am going to go with the this box and 3 - 10" W0-8s with a ZR240.
    Casey
    Mar 2005
    Ironton, Ohio
    Casey
    Yeah 99silverado is right a 57" box will fit fine. I measured it yesterday and can't remember the exact measurement, but I check to see if a 57" box will fit and there was room left over. He is also correct about having to take out you middle console. You will never get that thing in there without taking that out.
    Jon
    Feb 2005
    Louisiana
    Thanks for your time and help.
    Casey
    Registered User aaronb's Avatar
    May 2005
    sparks,nv
    the box in my 98 is 60" w x 18"h and it fits fine, im running three 12s
    98 stepside:hp 44,14bolt, 5.13's, 39.5" rockers on 15x12 bart wheels, doug thorely tri-y's,
