Results 1 to 19 of 19
urgent
This is a discussion on urgent within the Audio/Video Electronics forums, part of the General Discussion category; Am i suppose to take the big panel off thats black behind door panel to put deadener on inner door ...
    Forum Leader nebraskaz71's Avatar
    Aug 2001
    nebraska
    urgent
    Am i suppose to take the big panel off thats black behind door panel to put deadener on inner door or wtf. Took me forever to get a panel off and i broke 3 clips but now i'm confused and do i cover teh big vents in lower right corner
    No its not stock height!
    1998 GMC "TOY"
    2005 Chevy 2500HD "DAILY"
    100% Roots Rocka DSZ71's Avatar
    Jan 2003
    Sittin next to the Govenator
    Re: urgent
    do you have a digi camera, that would help alot. What you want to do is add raam mat to the insides of the metal door panel, and on the outside to seal it completely (minus door rods etc). This creates sort of an enclosure, also know as IB enclosure. The clips can be found at any local NAPA store, so they are easy to replace. Here are some pics of what I mean:
    inside of door panel
    out side of door panel, sealing it off
    **My Little Roots Rocka**
    Aug 2001
    nebraska
    Re: urgent
    K the inside of my door is covered with a black metal panel with like 40 lil screws haha i may have to take a pic
    1998 GMC "TOY"
    Jan 2003
    Re: urgent
    Then just add the matting to the oustide then...
    Aug 2001
    nebraska
    Re: urgent
    Taken apic now
    1998 GMC "TOY"
    Jan 2003
    Re: urgent
    cover it like that, just prep the area well
    Aug 2001
    nebraska
    Re: urgent
    aight good that looked like a biotch to take off. Do i covre that big vent on lower right side of panel also?
    1998 GMC "TOY"
    parrot on the bandwagon 95stroked1500's Avatar
    Nov 2003
    lala land
    Re: urgent
    taking that panel off is tricky because of the window. more than just the panel comes out.
    some deaden over it, some don't. it's all about what you want to trade off. blocking off a desinged cab vent or blocking more rear speaker wave. no big deal on the clips we all break them.
    Jan 2003
    Re: urgent
    block the vent. You window is leaky enough that blocking the vent is not a problem. Its not like you will create a venturi and suck in your doors or anything like that.
    FYI....venturi = vacuum suction
    Aug 2001
    nebraska
    Re: urgent
    Doors are covered with a layer that overlaps a ton hehe Still working on redoin my panels and then i gotta wire my tweets and crap back up. I should be done tomorrow and see how it sounds. So far i feel like its not gonna do much so hopefully it suprises me haha
    1998 GMC "TOY"
    Aug 2001
    nebraska
    Re: urgent
    1998 GMC "TOY"
    Jan 2003
    Re: urgent
    And your thoughts??
    Aug 2001
    nebraska
    Re: urgent
    Just finished with it ill get pics of what i actually did :) so far my thoughts are i can't notice very much if anything but i've drove it a total of like 45 seconds so we'll see with time.
    1998 GMC "TOY"
    Nov 2003
    lala land
    Re: urgent
    you should notice it in the midbass mainly. if not,....... what is the mid bass capability of the those speakers anyway?
    Aug 2001
    nebraska
    Re: urgent
    not a clue? lol
    1998 GMC "TOY"
    Aug 2001
    nebraska
    Re: urgent
    Covered door panels with black suede/leather stuff, painted speaker and tweet cover silver while i was at it. Let me tell you and anyone else to never ever do that!
    1998 GMC "TOY"
  17. #17
    loves Mickie James oldred95's Avatar
    Mar 2004
    Kiowa, KS
    Re: urgent
    What kind of sound deadener are you using? How did the door panel fit back in place with all that deadener? I kinda halfasses did mine with what I thought I could get away with because I didn't know there was that much room behind the panels to put deadener. May have to pull those back off and redo it. BTW, I broke a few clips but I glued them back with some high powered epoxy.
    1995 Silverado - ported vortec heads, 4L80E, efans, LT4 Hot Cam, Rear disc brake conversion w/drilled and slotted rotors
    1999 NBS Silverdo - transgo HD2 shift kit, 3 inch dynomax ultra flow, Ford keys and 305/70-16 Mickey ATZs
  18. #18
    Aug 2001
    nebraska
    Re: urgent
    I use Raamat. I broke two clips total. There is a ton of room behind panel
    1998 GMC "TOY"
  19. #19
    Mar 2004
    Kiowa, KS
    Re: urgent
    Quote Originally Posted by nebraskaz71
    I have and used some stuff I got from JC Whitney. Looks like carpet padding with aluminum foil on it. Well I know what next weekends project will be. BTW, I got my panels off with two screw drivers and it worked on.
