Results 1 to 7 of 7
Passenger Side Door Panel Speaker Inoperative
This is a discussion on Passenger Side Door Panel Speaker Inoperative within the Audio/Video Electronics forums, part of the General Discussion category; For some reason the passenger side door panel speakers on my 2000 Silverado quit working. Where do I need to ...
    Sep 2005
    Versailles KY
    For some reason the passenger side door panel speakers on my 2000 Silverado quit working. Where do I need to start checking for the problem?
    fknlow cajundragger's Avatar
    Apr 2004
    louisiana
    Re: Passenger Side Door Panel Speaker Inoperative
    at the back of the HU...
    2000 ECSB, 5.3, magna flow cat back, some beat in the back and a killer front stage
    Sep 2005
    Versailles KY
    How do you get to the Head Unit?
    Jun 2005
    Kentucky
    Check the speaker first and make sure it is not blown. Pull it out and use a battery and see if it moves when you hook up the leads from + and - . All you need is a D,C, or 9 volt battery.
    Registered User slowrider's Avatar
    Jun 2003
    georgia
    yeah, check out the speaker first. You are more likely to have a blown speaker, or a loose connection at the speaker than at the rear of the head unit.
    Roll Tide
    Apr 2005
    phoenix
    Talking Re: Passenger Side Door Panel Speaker Inoperative
    u should take it into the shop man
    take it to the dealership. You might get more of a response if you post this in technical....
    Apr 2004
    louisiana
    Quote Originally Posted by KenSilv
    doubt that.......umm I thought you would have checked the speaker and the speaker connections first........so go to your truck, drop the door panel and make sure the connector on the speaker is good and tight, if it is take a aa battery with alligator clips and test the speaker to make sure it works, if all is well still, then go to the back of the HU and check the speaker wires there...
