Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Head Unit Dash Mounting Kit Question
This is a discussion on Head Unit Dash Mounting Kit Question within the Audio/Video Electronics forums, part of the General Discussion category; I have a Clarion DXZ715 cd player and I bought a audio control epic 150 which is a 1/2 DIN ...
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    Question Head Unit Dash Mounting Kit Question
    I have a Clarion DXZ715 cd player and I bought a audio control epic 150 which is a 1/2 DIN size . Is there a dash kit that will allow me to mount it under my Clarion and keep it all in the factory location ? Sorry if this is a little confusing sounding . Any ideas are welcome as to how to mount this up . I attached a pic of what I'm talking about . It might be a little difficult to see .
    Check out my truck in the July 09 Sport Truck Magazine in the home grown haulers section
    If your looking to have an air bag suspension done dont use Joe Sulpy Customs in Ledgewood,NJ
    Registered User pickupman's Avatar
    Feb 2002
    Norman, OK
    does your truck have a true double din sized opening? If it doesnt it wont work without some custom dash work. Most GM vehicles have a special "GM sized" stereo. Its a larger design than the 1/2 din, but not quite double din sized which is what you need. If you have a double din size opening you could probably make some brackets yourself.
    '99 K1500 Z71 5.3 | 6" Fabtech | 315 MT/R's | TruckPC | Stuff
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    How can I tell if I have a special gm sized radio ?
    Want some? rollinstyle's Avatar
    Jul 2001
    Oklahoma City
    You've got like a 1 1/2 DIN sized opening like all GM vehicles. It won't work unless you cut down inot your little cubby hole and do some custom work.
    1996 Chevy Tahoe-2dr 2wd
    -Tint
    -Compustar 2-way paging alarm
    -Pioneer 850mp w/ 2 Pioneer 10" subs powered by a 900watt RF amp
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    Where else can I mount this ?
    2000 Silverado Dubyagee's Avatar
    Feb 2002
    US
    You head unit is single din and your EQ is 1/2 din? Then it should fit. you might have to square up the corners of the bezel to get it to work. as far as a "kit" your probably gonna have to fab something up.
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    I not sure if my head unit is a single Din or not . I think it is ? I have a pic of it on my web site . Click the link in my sig. to see it .It is in the gallery section .
    Jul 2001
    Oklahoma City
    Are you trying to put both of the little equalizer things in there? I don't think both of them will fit, but one should.
    -Tint
    Jul 2001
    Oklahoma City
    Your HU is a single DIN btw.
    -Tint
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    No , just the clarion cd player and the epic 150
    Registered User TR02Yukon's Avatar
    Oct 2001
    Don't know of any that allow it to go below but here is one thats above:
    http://www.scosche.com/scosche/insta...its/GM1484.asp
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    Would that one allow me to use my aftermarket cd player ? It looks like it would be used more for a factory head unit that you would be adding a EQ to .
    Feb 2002
    US
    One word.....Dremel
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    Talking
    One word.....Dremel
    That exactly what I thought
    Feb 2002
    Tulsa
    That's an adapter for a single DIN head unit and a 1/2 DIN EQ. It's what you need.
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    Anyone know where I can find that kit ( http://www.scosche.com/scosche/insta...its/GM1484.asp ) . I tried sound domain but they did not have that one .
  17. #17
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    I was wondering if someone could tell me how I can figure out which wire to use for a remote turn on lead (would like to do it correctly) ? The guy that installed my first amp used a terminal in the disturbution block (Big gray block with a couple of relays in it on the drivers side firewall ). I installed everything and the epic 150 wont turn off when I turn the key off . If someone knows another reason for this please let me know .
  18. #18
    Feb 2002
    Norman, OK
    My head unit has a wire in the wire harness for a remote turn on. It is a light blue color but that might be just for sony?. Check your head unit owner manual to see if it has a wiring diagram.
  19. #19
    Ynot? ynot's Avatar
    Feb 2002
    Point Pleasant,NJ
    Arrow
    pickupman thanks for the info . I have two blue wires left in the harness that are not connected to anything . I am wondering if one of them is the remote ? I checked my clarion's owners manuel and it had no info on the wires . Why did I have throw the bag for the wire harness out :to: .
  20. #20
    YAAAAAaaaaaay FeeD's Avatar
    Sep 2001
    lockport, NY
    remote and power antenna maybe
    04' sierra - coolride and slams up front, kp in the back
