Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Anyone up for a huge challenge? What is the volume of my sub box?
This is a discussion on Anyone up for a huge challenge? What is the volume of my sub box? within the Audio/Video Electronics forums, part of the General Discussion category; Here is the best I can do with Paint. It is 44" wide with a .75" divider at the center ...
    Registered User Intercooler's Avatar
    Jun 2005
    North East, MD
    Here is the best I can do with Paint. It is 44" wide with a .75" divider at the center seperating the two sides. It measures basically 10" in the front and tapers down at the back to roughly 6.5" with the mid-point being 8"H. It also has a 12"L 3.5"H step at the bottom to clear the hump in the middle of the truck. The ports on it are 3.5" Dia with a 4"L on the insert going into the box. This is the box I got of E-Bay used so I am trying to figure out subs to slam in it. I would like to go two 10" RE-SE's or similar if they will play right. Anyone know how much cubic ft. I have roughly per side?
    Attached Images Attached Images
    1999 Z-71 4WD ECSB WITH 5.3, AUTO and 3.73's
    100% Roots Rocka DSZ71's Avatar
    Jan 2003
    Sittin next to the Govenator
    Re: Anyone up for a huge challenge? What is the volume of my sub box?
    I get 2.02 cu feet total. But if you do some simple math, your measurements dont match up.
    You say the total width 44", with a 0.75" divider in the middle.
    So thats 43.25" to each side, your center section is 12" and the rest is 14.5".
    So if you add 14.5 x 2 = 29+12" = 41". Where does the other 3" come from? I know you have a center section, but thats only 0.75"
    **My Little Roots Rocka**
    Jun 2005
    North East, MD
    More accurate info.
    The box is 49" overall end to end. Subtract .75" x 2 or 1.5" so inside length is 47.5". The raised portion is 17.5" long, not 12". Does your calculation take into account the taper of the box that is has to fit under the seat from 10" in the very front to 6.5" at the rear? If I can squeeze out 1.0 cubic foot after taking out the sub basket I may have it.
    Jan 2003
    I took the measurements as 44 being the outside edges, I didnt know you already subtracted them...in that case, yes you have 2.05cu feet. The taper is easy to figure out, its the two heights added together then divided by 2.
    Jan 2003
    Quote Originally Posted by Intercooler
    More accurate info.
    your picture says 12" thats why I asked...
    Jun 2005
    North East, MD
    My measurements were off. Given 47.5" and 17" for the middle section where it is raised 3.5" for hump clearance about how much do I have per side? Any suggestions on subs that will work well in there?
    fknlow cajundragger's Avatar
    Apr 2004
    louisiana
    I say plug the ports and throw whatever you want in there sealed...
    2000 ECSB, 5.3, magna flow cat back, some beat in the back and a killer front stage
    Jun 2005
    North East, MD
    Quote Originally Posted by cajundragger
    Any idea what volume I have? How does one go about plugging the ports? That is what I would like to do! Just how to do it and it be right?
    Jan 2003
    That total volume is too much for a pair of 10s. You might be able to modify the mounting holes and toss in some 12s in there. Your volume is just over 2 cubes....it hasnt changed from what I posted above...
    Just divide it by 2 to get your "per side" volume...
    Jun 2005
    North East, MD
    Quote Originally Posted by DSZ71
    RE's site says an SE-10 takes .65 sealed and 1.25 ported to 32 Hz and a SE-12 takes 1.0 sealed and 1.8 ported to 32 Hz. Which do you suggest for me?
    Jan 2003
    Hmm....you have about 1.0 per side sealed....that should be easy...
    Jun 2005
    North East, MD
    Only problem is the box isn't sealed yet with holes for the ports in it. How do I go about fixing that?
    Jan 2003
    Remove the ports. You may want to try and cut out the same diameter from some scrap MDF to plug the holes. I would add a flat piece of MDF behind the holes (from inside the box) as reinforcement. Wood glue should be strong enough to hold it in place. You might need to re-cover your box so you cant see the modification...
    Jun 2005
    North East, MD
    Thanks for your help!
    It also has those black inserts at each end (like 2" diameter) where you attach the speaker wires. I thought I read they aren't good either and that you are better off just cutting a small hole for the wires to run through and siliconing them in place. If that is the case I need to plug those too.
    As to fixing the holes. I see what you mean about say cutting a 4.5" diameter piece of MDF to cover the 3.5" hole on the inside with silicone and screws. Should I also make another 3.5" round piece and put it in the whole with silicone? Or maybe use Plexi?
    Jan 2003
    Okay, so say the diameter of the hole is 3.5. Cut a piece thats 5" diameter for the rear PLUS an additional 3.5" for the hole itself. Dont use Silicone! Use wood glue and clamp it down so its tight. Once the glue has dried, take off the clamp. Wood glue is stronger bonding than silicone...
    Dont worry abou the terminal cup, just use them. If you have worries, seal the inside with some silicone
    Jun 2005
    North East, MD
    They are at the ends which is kind of ugly having the wires hanging out there. I don't know why the person had it built that way. Running them to the back would make much more sense! Doesn't terminal cups prevent SQ?
  17. #17
    Jan 2003
    If the are installed correctly why should you lose quality? They need to be airtight, since its a sealed box (or will be when you cover the port holes).
  18. #18
    Apr 2004
    louisiana
    you have to go 10's, you cant put a 12 in a box that is 10 inches tall...
  19. #19
    Jan 2003
    Good observation mane, I didnt even notice that...well done
  20. #20
    Apr 2004
    louisiana
    thank you thank you, and to revise what I said, you cant even fit a 10 in a box that is 10 inches tall, or I know at least my IDMAX is a 10" sub and you need about 11 3/4 off height to fit it....
