Results 1 to 17 of 17
Alternator install
This is a discussion on Alternator install within the Audio/Video Electronics forums, part of the General Discussion category; ok i just got my 235amp alternator in ( for my 03 tahoe) and i was wondering how to install ...
    Its a Chevrolet!!!! Mattman24's Avatar
    Jun 2005
    Tyler, Texas
    Alternator install
    ok i just got my 235amp alternator in ( for my 03 tahoe) and i was wondering how to install it
    i know the it bolts right and u connect all the wire and such, but what about the belt how do i get it to be tight?
    Also am i forgetting anything else? please enlightin me
    thanks
    Matt
    2008 Silverado 1500 LTZ Z71 4x4
    2003 Tahoe - all custom - SOLD
    FSC Texas Chapter
    Apr 2005
    phoenix
    Re: Alternator install
    youll have to take off every pully and turn them 180*
    than change the bolt style 2....
    j/m their is a auto-tensioner *****
    Jul 2003
    England, UK
    just take it to someone and have them install it for u, if u know that it takes bolts and wutnot, then u should know about the belt
    also ur probably gonna need the longer belt for the bigger style case alts
    peace
    2k gmc, sold!
    84 classic mini cooper, rhd, VP Austin metro 1275, stage 1 kit, coil spring conversion kit, 6point roll cage, classic bucket seats/4point harness, 13inch weller rims on yoko rubber, matt black
    Dec 2005
    St. Paul, MN
    Get yourself a service manual.
    Is this an alternator that is meant to replace the stock one? Or some universal deal?
    Jun 2005
    Tyler, Texas
    Quote Originally Posted by Cray91
    yeah this is ment to replace the stock on, im taking to somebody later on today thanks
    FSC Texas Chapter
    Get in sit down hang on. SolMan98's Avatar
    Jul 2003
    Dallas, GA
    if the casing are the same, it's an easy swap. couple of bolts and a quick connector on the harness. to take the tension off of the belt, a 3/8 drive ratchet on the tensioner makes it a breeze.
    if it's not the same casing (as mine was not) then you will probably need a 1" or so longer belt.
    D/D-2006 HHR 1LT 5-Speed.
    1996 Silverado, 5.7, FIPKII, Elect Fans, S/S Headers, Duals, Wait4Me, 4/5 drop on 18" Weld Evo Velosity's. STOLEN ON 9/9/2006
    Jun 2005
    Tyler, Texas
    thanks guys i got it on and its running great
    FSC Texas Chapter
    stock schmock
    Nov 2005
    deep south
    Where did you buy it? Price? Do you have any pics? My T212 needs more juice.......the stocker can't cut it.
    stock schmock
    Nov 2005
    deep south
    (Again) Where did you buy it and for how much $$$$$? I need a 200+ amper in a bad way. My headlights almost turn off.........
    What was the idle output?
    Registered User loud_N_large's Avatar
    Sep 2005
    missouri, georgia
    There are a few places you can find an alt. I just got mine (300amp alt.) from Dommincik Iraggi(not sure if his fisrt name is spelled right). Solid alts, great service, or theres excessive amperage. Also good products. You can also have your alt rebuilt, though I am more partial to a new alt all around, as I have had less probs with new than rebuilt/upgraded alts.
    Sep 2005
    missouri, georgia
    I think I paid $400 for mine, plus shipping. Well worth it in my opinion though, I'm even looking into getting a second one thrown on my 'hoe
    o3 'hoe
    4-xxx15''s
    2-xx-colossus
    2-tx8805's
    1pr-xxxmids
    1-audioepicenter
    1-audiocontrol DQT
    carcpu lite+ pc
    10.2" touchscreen
    4-optima yellowtop batts.
    1-iraggi 300amp alt.
    TL SPL meter
    Registered User 99Escalade's Avatar
    Oct 2002
    sugarland,tx
    loud n large: do you have any pics of your 10.2 screen set-up?
    Adam
    04 Caddy Escalade bagged on 4's
    96 Impala SS show car
    87 Chevy C-10 Satin Blue
    Sep 2005
    missouri, georgia
    I wont have any pics of it till I return to the states. But, assuming all goes well here, that will be in a matter of a week or two. As soon as I do get back, I will post some pics up though.
    o3 'hoe
    4-xxx15''s
    2-xx-colossus
    2-tx8805's
    1pr-xxxmids
    1-audioepicenter
    1-audiocontrol DQT
    carcpu lite+ pc
    10.2" touchscreen
    TL SPL meter
    Jun 2004
    Nantucket, MA
    I have one of the excessive amperage 200 amp alts. My tahoe idles at 500/600 rpms....and the alt doesn't produce anything until it sees 700/800...so everytime it idles the voltage drops to 12 volts and drains right off the bat.
    Anyone else have this issue....how can i fix it. I am pretty sure it already has the smallest pulley on it too.
    Sep 2005
    missouri, georgia
    You can grab a new alt, one that has a higher amperage output at idle. Or you can look into a second battery. Something lika a yellow top or one of its competitors. Also, make sure you did "the big 3" otherwise, your alt isnt going to be able to operate to its full potentiol.
    o3 'hoe
    4-xxx15''s
    2-xx-colossus
    2-tx8805's
    1pr-xxxmids
    1-audioepicenter
    1-audiocontrol DQT
    carcpu lite+ pc
    10.2" touchscreen
    TL SPL meter
    stock schmock
    Nov 2005
    deep south
    Will an alt from a NBS fit on an OBS with little to no mods?
  17. #17
    135AMPS@IDLE! ratt ron's Avatar
    Oct 2005
    bristol tn.
    halfAhoe, pm sent
