Results 1 to 15 of 15
88 CD Player Install - HELP!!!
This is a discussion on 88 CD Player Install - HELP!!! within the Audio/Video Electronics forums, part of the General Discussion category; Hey guys, I'm new here and have a really tough question. I just bought an 88 Chevy truck off a ...
    Jan 2006
    Muncie, IN
    Hey guys, I'm new here and have a really tough question. I just bought an 88 Chevy truck off a fella and it is in desperate need of a CD player. I've installed numerous CD players before, but this one is nothing like I've ever done. All the others I've done, you just unplugged one and plugged in the other. In this 88, I took out the stock deck and stock tape player and have no idea what to do?? ANY help is appreciated. Thanks. -Justin
    The Great Dionysus
    Jul 2005
    Dallas, TX
    Re: 88 CD Player Install - HELP!!!
    Quote Originally Posted by JAKennedy2
    There is an external amp on those trucks that you will need to uninstall. You will need it for the speaker wires. It is under the dash. The CD player will have to go where the tape deck went. What other info is troubling you?
    '02 Chevy Reg cab
    Pioneer P9 combo
    Polk Db1000 (SoundStream D100)
    Coustic Ref. 4" mids (JBL 75.2)
    Adire Extremi 6.8 (Memphis mc-300)
    Stereo Integrity Mag D2 (Memphis mc-1000d)
    1.2 cubes sealed
    formerly P379XL SimpleGreen's Avatar
    Sep 2004
    Livingston, LA
    Buy a Scosche intall kit from your local WalMart. It'll have everything you need, including the directions for all the wiring (what like what needs to come out in these old trucks) and the new face plate too because the old one isnt deep enough. I used the Scosche to install my Pioneer...its a good way to go.
    - 1993 C1500 - 5.3L/4L60E Swap - 3/5 Hotchkis - '96 Interior - Tuned by EPS -
    - 2012 Camaro V6 1LT - Victory Red -
    Jan 2006
    Muncie, IN
    I've always seen them installed under the vents in the middle of the dash. A buddy of mine has a truck almost just like mine and his is right there. My other question is what do I do with the wires on this install. I'm used to just plugging in the harness, is that not going to be the case with this install??
    Jan 2006
    Muncie, IN
    I've purchased the install kit from Wal-Mart and that is being no help. When i took out the factory CD player, it had wires directly soldered onto the board. Then, I took the factory tape deck out and it also had wires directly soldered onto the board. That is where I'm so confused...
    Jan 2005
    East Coast Canada
    above the gas pedal to the right is a silver box.It is the external tuner and amplifier.Remove the 3 9/32" screws and drop it down and unplug it.This will give you a standard Gm plug for your harness adapter.You know you have found the right box because it also has the antenna plugged into it.
    Jan 2006
    Muncie, IN
    V8Sonoma: Thank you very much. I looked under the dash and found the box and thought it may have something to do with it. Now, I know it does. Again, thanks a bunch. -Justin
    Sep 2004
    Livingston, LA
    Did you buy the actual 88-94 Chevrolet kit that comes with the new face plate that goes around the middle vents and everything? If so, all the directions should be in there. They were in mine...but, w/e...
    Jan 2006
    Muncie, IN
    No, my instructions didn't come with the directions. It was merely a small box with the connector and an antenna adapter. I did successfully install the deck (with help from everyone here) and I greatly appreciate all of your help. Thanks again. -Justin
    TLS
    TLS is offline
    Feb 2004
    N&W Philly Burbs
    With my old '90 I just ordered everything from Crutchfield. It came with all adapters, and even a nice storage pocket for the old radio location. Came with speaker wire adapters and everything. Excellent step by step instructions with vehicle specific pictures.
    I don't know if they still offer all this stuff, and if they do whether they offer it for such old vehicles anymore.
    I always liked dealing with Crutchfield. Never any problems, FAST shipping and pretty decent prices.
    '04 GMC 2500HD 6.0 9.2 BOSS V Plow
    '99 300M
    '05 Legacy GT Limited Sedan
    Previously Owned:
    '90 K-3500 SRW EC 454/TH400 BOSS V Plow
    '76 K-10 Reg Cab built 350/4speed Meyer Plow
    Jan 2006
    Muncie, IN
    Hey guys, I've got another quick question. When I installed the new CD player and dash piece, I can't seem to get the bottom on the dash piece to "click" into place. This isn't a really big deal, but it just makes it a whole lot easier for someone to steal it, etc. Any help is appreciated. -Justin
    Truckin' Fool Frankenbiker's Avatar
    Jun 2005
    Grand Prairie,TX
    You'll need to remove the metal clips from your old dash piece and put them on the tabs on the new one. You may also be able to buy the clips from your stealership. They're designed to dig into the plastic, to keep them from coming loose, so you may have to "persuade" them a little.
    -blaine
    Jan 2006
    Muncie, IN
    I got the two clips from each side, but it still won't go. It's almost as if the deck is too deep (could that be possible). Plus, if i try and push it in really hard, the deck itself starts to come out of the dash unit. -Justin
    Jun 2005
    Grand Prairie,TX
    Then the deck is too deep. There's not a whole lot of room in the dash to shove stuff. You might try moving some of the wiring around to make sure it's not taking up that extra 1/4 inch you need...
    As good as the early OBS trucks in other regards, GM *REALLY* dropped the ball on this particular item. One of the few time when I give GM's engineers an Idiot Award(tm).
    -blaine
    Jan 2006
    Port Angeles WA
    If you use a METRA Dash kit , it comes with a 1" extended trim ring. This helps out for those decks that are a little deeper than normal. Plus use your backstrap! That helps to keep the deck in place ....so when you hit a bump those @#$!@# clips don't un-snap. Use a #8 X 1/2 pan head screw to fasten the back strap to the lower heater box and if you use ONLY a 1/2 " screw you wont "peg" anything inside......
