BTW i want to push two 12" at 4ohm's each.
This is a discussion on 300rms x 2 within the Audio/Video Electronics forums, part of the General Discussion category; ok i'm looking for an amp that can push around 250-300 rms for a while without getting so hot to ...
ok i'm looking for an amp that can push around 250-300 rms for a while without getting so hot to the point it shuts off. The amp i got right now can run for about an hour then shuts off because of the heat. What are some good options? thanks
Look for a good class D amp! Look in to a Kicker kx4001 mono, it runs at around 400watts but most that i have seen test out a little higher they really under rate thier stuff. My question is are you asking for a total of 300rms for both subs or per sub?
Mtx ta4501 is certified at 500x1 @2ohms
kicker kx6001 is rated at 600x1 @2ohms
both mono!!
http://www.mtx.com/caraudio/products...hunder4501.cfm
http://www.mtx.com/caraudio/products...hunder5601.cfm
I'm looking for 300rms per sub
go for the kicker 6001 it a pretty kick ass amp We sell them for 369 right now because the new one will be out in march!!
Thanks man anyother options out there?
Directed 1100d at ikesound.com. Only $133.95 shipped. Maybe alittle too much power but you can always turn the gains down, and you will have room to upgrade in the future.
I have mine pushing 500 to each of my Type-Rs and I couldn't be happier.
What brand amp you running now?
Also, what gauge wire is running to it?
And to note, the Directed doesnt seem like a bad deal either. Seems almost too damn cheap to be true, lol.
LOL i got a cheap azz Audiobahn A6004T got it dirt cheap tho, but the damn thing blew 5 days laterI'm running a 4ga power to a distribution block than have two 8ga wires to the amps themselfs
Rockford T5002, it is a great amp little pricey but definitely worth the price. I have mine on 3 12's running at 2 ohm stereo and it pounds
96 Chevy 1500 Ext Cab-The Daily
95 Ranger Ext Cab-Now Gone
2003 Usaci World Champ SS151-300 162.4db
2004 Padre Champ SS0-300 155.2db Termlab
