Results 1 to 9 of 9
Will a factory slave CD player just plug right in?
This is a discussion on Will a factory slave CD player just plug right in? within the Audio/Video Electronics forums, part of the General Discussion category; I have the factory tape deck in my 95 tahoe, and a friend of mine has the Slave CD player, ...
    has no car payment! TIMSPEED's Avatar
    Jan 2003
    Modesto, CA
    I have the factory tape deck in my 95 tahoe, and a friend of mine has the Slave CD player, but she also has an aftermarket Deck. She said I can have the slave, if it'll work for me.
    Will it?
    -87 Corvette Z52 Coupe
    *K&N Filter,Yank Torque Converter,Custom Cat-Back
    -95 Tahoe 2-door 4x4
    *Posi-Lok/G80, 285's, Custom Cat-Back, 3.73's
    -96 S10 ECSB V6
    *ZQ8 Rims, 3" BellTech Drop, Dynomax Cat-Back
    Jan 2003
    Modesto, CA
    Re: Will a factory slave CD player just plug right in?
    TTT
    Anyone know if this will just plug right in?
    -96 S10 ECSB V6
    Waitin on Christmas Slinky05Crew's Avatar
    Feb 2003
    Rouses Point, NY
    you will need the wiring harness that goes from the slave to the deck out of her vehicle...i had taken one out of my 97 gmc that i had and put it in my buddies 95...just needed to run that wire from the cd to the deck. worked fine.
    2005 Chevy 1500 Crew Cab 4x4 debadged, 20" Icon W68 w/ Nitto Trail Grapplers (on order), MBRP 3.5" exhaust, Dynatech Stainless Long Tubes, K&N, Airraid mid pipe, few other goodies
    Jan 2003
    Modesto, CA
    Quote Originally Posted by Slinky05Crew
    Well, I'm sure she has the connector, and it's probably not connected because she has a Kenwood deck, so I'm sure it's probably just hanging in there..it should just "plug" right in right? no splicing needed?
    -96 S10 ECSB V6
    Feb 2003
    Rouses Point, NY
    Quote Originally Posted by TIMSPEED
    right...might be a pain to fish out the connector..but thats about it.
    Jan 2003
    Modesto, CA
    I have a feeling her connector is CUT and hanging in there..we'll see...Thanks for the help!
    BTW: Any stock deck will control the stock CD player right?
    -96 S10 ECSB V6
    Feb 2003
    Rouses Point, NY
    of the mid90-s and up style, yeah...there should be an Aux button i believe...if the cable isnt there i can look to see if the one my friend had in his truck is still around because i never put my cd player back in when i got rid of the truck and he's running a full aftermarket system in his now. let me know and i'll try and help ya out.
    Jan 2003
    Modesto, CA
    I appreciate the help! I'll let you know. I'm supposed to swap stuff on thursday night, so, I'll let you know what I find (or don't find)
    Be cool if it works out for me, because I don't want a fancy aftermarket deck, because I only really listen to the radio, but it would be nice to have just a factory CD deck, so if I wanted to, I could.
    -96 S10 ECSB V6
    UNDER CONSTRUCTION.......
    Nov 2003
    indiana
    i highly doubt it would be hacked unless the whole radio was hacked up by A HACK RETARD!
    mine was realy easy to remove... im sure instaling it wouldnt be to hard as well.......
    id say try using a coat hanger bend it around to snake it thru the rear plastic then once its ran tape or zip tie to the wire to the hanger and simply slowly pull it thru....
    shouldnt be to much of a problem to do.
