the dayton or cvr IMO
Kicker Comp VR 10
JBL GTO 10
Orion C2 104
Crystal Audio PRO X210
Dayton High Fidelity 10
This is a discussion on Help me pick a sub!!! within the Audio/Video Electronics forums, part of the General Discussion category; Ok, so me being the retard I am realized that the Ascendant Audio Assassin was only a single voice coil ...
Ok, so me being the retard I am realized that the Ascendant Audio Assassin was only a single voice coil @ 4 ohms... this won't do cause I need 2 ohms. Right now I really dont want to think about car audio any more.. so I'm leaving this one up to you guys.. I need something that will do well in around .8 cubic feet sealed, and does well with only 280 watts rms @ 2ohms. SQ is more important than SPL
Heres the links to all the poll choices... Let me know what you picked and why or leave your own suggestion. Goin in a reg. cab so the sub cant be too deep...under $120 ish.
Kicker Comp VR 10
http://www.cardomain.com/item/KIC05CVR104
JBL GTO Series 10
http://www.cardomain.com/item/JBLGTO1004D
Orion C2 104
http://www.cardomain.com/item/ORI27055
http://www.crystalmobilesound.com/subwoofers.htm
Dayton 10in High Fidelity Sub
http://www.partsexpress.com/pe/showd...number=295-460
'02 Z71 - Pacesetter LT's & ORY - Homemade Magnaflow catback - Homemade Intake - 285/75/16 Geolanders - Wilde Tuned!!!
dayton
i'd drop the jbl and orion and choose between the other 3.
yeah i think im gonna go with a dayton... there is actually a guy that sells em right over in Utah soo ill probably order from him instead of parts express in the hope of cheaper shipping.. should i get the high fidelity or high output... im only gonna be giving it 280 rms... hah.. some of the values change to make the HF require a bigger box... if you could look at these values?
Param. 10HO 10HF
Fs 24 Hz 22 Hz
Qms 4.2 2.8
Qes 0.36 0.45
Qts 0.33 0.39
Vas 34 L 60 L
Re 3.4 Ohm 3.3 Ohm
Le 1.75 mH 0.95 mH
VC Dia 2.5" 2.5" cm
Xmax 12mm 14mm
Power 600W RMS 350W RMS
1000 W Max 600 W Max
SPL 87 dB @ 2.83V/1m for both
i mean the comp vr is the only one ive heard and it doesnt sound bad to me but i mean thats also listening to it at us tech and circuit city... soooo. blah. im gonna order my headunit and amp wiring kit tomorrow... i cant wait to start getting packages from ups
oh and for the same price as the dayton, what is the story on adire audio shivas? ive heard some people complain of things breaking...
1st choice = Dayton.
2nd choice = Kicker.
I'm not a fan of the Orions, and don't care for the JBLs. Don't have any experience with the Crystal's, so I can't comment on them.
I have an older 12" Kicker Comp VR that I have been very satisfied with, but I'm planning on running 2 12" Dayton HO's later this summer. I've heard good things about them, and for the money, they're worth a try!
'99 Tahoe - Whitey
'03 Tahoe - Blackey
Well ive been messin around on the image dynamics forum and as it turns out theres gonna be a new generation of IDQs released in about a month. soooo maybe i will wait until after my vacation to buy a sub... if its out ill get it if its not ill probably go with the dayton..
you can find IDQv2 online for 120ish. Better driver than any you listed with exception of the Dayton.
Cvr
Maybe its a little late but have you thought of Boston Acoustics? I love mine. It is a G2 and it rocks.
http://www.bostonacoustics.com/car/c...category_id=17
I have used several comp vr's and have been very pleased. i would also suggest buying off of ebay. u can get a comp vr 10" for probly $60-$70 shipped. i got mine from ebay and have had no trouble at all with them.
You may want to look at both versions of the Dayton; the HF and the HO (same price). In case you are not aware, unless I'm mistaken, the HF version requires a larger enclosure than does the HO version - just in case you have space constraints. The Parts Express tech people can help you with any questions.
88 Extended Cab
Might I suggest you look at the 11Kv.2 sub by Elemental Designs.
This would fit your need nicely as well.
Out of your options Id go with the Dayton (whichever version fits your box size/ power specs)
Dave.
I was just going to post the same thing. 11Kv.2 gets my vote.Originally Posted by TWKTCC
Insert sig here.
**** eDuh.
lol well my mind has flip flopped around on this alot, and im on vacation right now... until the 31st of july and im not around my truck so i figure i wont make a decision until i get back.. if the new Image Dynamics arent in production like their dude told me they would be i think im gonna just splurge on the sound splinter RLi 10... i heard somewhere image dynamics builds the eD stuff, is that true? ive never heard anything bad about ID so how could eD be that bad?
ed builds ed stuff. They may use some of the same suppliers as ID as far as baskets and things like that go, not sure.Originally Posted by Unrthdxdream
Insert sig here.
I havent heard any of those
but Crystal usally give more value than most brands
02 Silverado LT
ed doesn't not build any of their own stuff. it is all from buildhouses elsewhere.Originally Posted by Vince
Image Dynamics used to make eD's speakers, but as with every buildhouse previous to the current one, there were several issues that arose on the eD side and the buildhouses moved on. if i remember correctly, lack of timely payment was the issue at hand for Image Dynamics.
Originally Posted by Punk0Rama
You're right. I guess what I should have said is ed's stuff isn't just an ID item with an ed logo slapped on it.
Insert sig here.
