Results 1 to 3 of 3
Installing to Fosgate P3001's
This is a discussion on Installing to Fosgate P3001's within the Audio/Video Electronics forums, part of the General Discussion category; Looking for advice on installing an additional P3001 Fosgate amp. I currently have one w/ one 10" sub. I'm looking ...
    May 2006
    Louisiana
    Looking for advice on installing an additional P3001 Fosgate amp. I currently have one w/ one 10" sub. I'm looking to add another sum + amp. The Fosgate tech support rep said that the manual outlines how to set the second amp a as 'slave' (if the manual says it, I can't find it). As 'slave' the second amp shares the gain & bass boost from the first, essentially mirrioring the settings.
    Any advice w/ this is greatly appreciated.
    By the way... I highly recommend JP Customs - quality business!
    Apr 2006
    louisiana
    Re: Installing to Fosgate P3001's
    you can't do that with that amp
    Apr 2006
    Knoxville, Tn.
    Actually it is possible. Simply run a second set of rca wire from the output of the first amp to the input of the second amp. Make sure you use seperate power wires to power up the second amp. This will work fine.
