Results 1 to 8 of 8
fuse on the remote wire
This is a discussion on fuse on the remote wire within the Audio/Video Electronics forums, part of the General Discussion category; i have a clarion head unit the remote wire doesnt have a fuse on it, should i fuse the remote ...
    Registered User slicpartna's Avatar
    Feb 2002
    Bham, AL
    should i fuse the remote wire?
    Aug 2005
    United States
    Re: fuse on the remote wire
    No you dont have to.
    brett
    Grumpy Old Man TWKTCC's Avatar
    Jun 2006
    In my truck
    Alot of older headunits had a 1A fuse in a twistlock fuseholder on the remote out, newer units don't. If you short the remote wire you will kill its output from the headunit, thus needing to send it out for repair. You sure can put a fuse on this wire.
    Dave
    Feb 2002
    Bham, AL
    i think that i will put a fuse on the remote wire
    i paid too much $$$$ to see something happen to it
    why would the new head units not come with fuses on the remote wire?
    most unique username
    Oct 2001
    Bainbridge, NY
    like everything else, manuf's cheap out where they can.
    Apr 2006
    louisiana
    the output of the remote wire is fused through the fuse thats on the deck. if it shorts out it will blow the fuse on the radio thus killing the power. it wouldn't hurt to put one on it but its not completely neccesary.
    nick
    Jun 2006
    In my truck
    Quote Originally Posted by nickypicky85
    nick
    Unfortunately this isn't the case. You would normally blow a diode on the pcb. Those fuses are to protect the circuts they are on.... 12v constant and ignition. Ive seen many decks come thru for install that function flawlessly but the remote out is toast.
    Jan 2006
    MN
    Of course, if it does die you can always wire it to the acc on wire...
