Results 1 to 6 of 6
Dual Battery Wiring Help
This is a discussion on Dual Battery Wiring Help within the Audio/Video Electronics forums, part of the General Discussion category; I want to install a second battery. I already have a deep cycle battery for free that I want to ...
    I WANNAGOFAST-Ricky Bobby
    Jul 2005
    Raleigh, NC
    Question Dual Battery Wiring Help
    I want to install a second battery. I already have a deep cycle battery for free that I want to install. Can I hook em both to the alternator and then ground separatly. Im not sure because one is deep cycle the other is optima red top 34/78
    Any advice?
    Jasper Stage 2 Crate, True Duals and no cats, open air element, Chip from brian @ tbichips.com, 160 stat, NBS wheels, 285 Uniroyal Laredo AWT's
    Soon to finish nv3500 swap.
    most unique username
    Oct 2001
    Bainbridge, NY
    Re: Dual Battery Wiring Help
    use the search feature for "dual battery" alot of info out there already.
    In a dual battery setup, the batts should be equal - the same make/model/size/ect.
    Registered User enine's Avatar
    Feb 2005
    OH
    If you wire two straight together they should be the same, since you have different then you should probably isolate them. You can do this with a relay or a diode isolator, each has advantages and disadvantages.
    2004 Silverado ECSB 5.3L z71
    1982 Palomino Bronco 186
    1991 Specialized Rockhopper
    2009 Giant Cypress DX
    Its a Chevrolet!!!! Mattman24's Avatar
    Jun 2005
    Tyler, Texas
    i have a 200amp stinger relay isolator works fine, havent had and problems
    Matt
    2008 Silverado 1500 LTZ Z71 4x4
    2003 Tahoe - all custom - SOLD
    FSC Texas Chapter
    Feb 2005
    OH
    You just have to be careful with the relay "isolotor" since it doesn't isolate when connected so you could have a dead second battery load down the starting battery to where you can't get the truck started. I wanted to be able to run my second down so I used the true isolator (diode) to keep them seperate even when charging.
    Jul 2005
    Raleigh, NC
    i appreciate the help guys. Im going to the marina tomorrow they have all sorts of different kinds of isolators. I will set them up to charge separatly.
