Results 1 to 11 of 11
Sold my stereo...time for upgrade (KICKER)
This is a discussion on Sold my stereo...time for upgrade (KICKER) within the Audio/Video Electronics forums, part of the General Discussion category; I sold my system to a kid down the street, and made a little profit.....Time to upgrade to an all ...
    Jul 2005
    Longview / Kilgore, Tx
    I sold my system to a kid down the street, and made a little profit.....Time to upgrade to an all Kicker system. Will my set-up be a decent mid grade system?
    2000 xcab silverado
    Probox
    2 Kicker cvr 10's 2ohm ($99)
    Kicker amp ZX750.1 ($239)
    Kicker RS65.2 components ($169)
    Kicker amp ZX150.2 ($79)
    still have Kenwood HU KDC-MP5032
    all comments are welcome......
    Jan 2006
    MN
    Re: Sold my stereo...time for upgrade (KICKER)
    With that much power, I'd like to see thicker mdf in the box. I'd look into having one made for you, or doing it yourself. Are your doors at least deadened? Those comps will love you if you deaden up your doors a bit.
    SLACKIN' CARLISLE BISH Jokeman's Avatar
    Oct 2001
    Boston
    Check out SubThump for boxes.
    If its loud, fast and runs on flammable liquid......count me in.
    Built LQ9...blah blah blah
    May 2006
    denver,CO
    good setup i would also add a crossover
    Oct 2005
    Boise, Idaho
    Your amp is rated at 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms) I suggest you go with 4ohm woofers so that you can run at 2 ohms mono. Otherwise you will have to wire your woofers in series for a 4 ohm load.
    A well built ported box and you will be happy with your components.
    Shawn
    Jun 2005
    Mesa, AZ
    where are you getting two CVR's for $99? Also did you mean dual 2ohm for them as well, I didnt think they came just as a 2ohm but I dont know much about kicker at all.
    Aggie Class of 2012 mitchellz71's Avatar
    Sep 2005
    austin texas
    i would recomend the deading as well. i have aroun 90watts going to mine and they ratle
    '98 ECSB Z71 DC lift with 35 MTZ's and yukon 4.88s Kappa 6.5's and 6x9's PG 600.1 PA LT 960 2 10" Assassins sold
    new truck- '04 Silver CCSB lt z71 5.3l 3.73
    Jul 2005
    I already have the Probox for the 10's.....will the box really make that much of a difference? And i can get dvc 4ohms if that would work better.
    I'm All Tip thekl0wn's Avatar
    Apr 2005
    PoCo, IN
    Dual 4-ohm subs can be wired to either 2 or 8 ohms... When those two are wired together, then you'll have either 4, 1, or 16 ohms... None of which is what you should probably shoot for. Go with the dual-2-ohm subs.
    '99 Tahoe - Whitey
    '03 Tahoe - Blackey
    Oct 2005
    Boise, Idaho
    Oops, sorry. Read your post to fast. The CVR's are dual voice coil. The two ohms will work well for you. If you wire each in series and then parallel to each other, you will get a two ohm load at the amp. The box makes all the difference.
    Where are you getting two 10" CVR's for $99?
    Shawn
    Jan 2006
    MN
    Quote Originally Posted by vonerick
    The box makes a HUGE difference.
