does it fit into the harness correctly? If not, its the wrong harness and theres no way to make it fit. If it does fit correctly, then:
The harnesses you can buy are not specific to your individual car, they work on any car that has the same plug. With that, some cars are going to have illumination wires that others dont and so on. Unless you bought the GMRC-01 for whatever outrageous price circuit city charges, the only wire you will have to run separate is the red accessory wire, which can be plugged into the fuse panel on the drivers side. There's a few little metal prongs sticking out on the bottom left of the fuse panel, ONE of those is accessory
-Cody
LinkBack URL
About LinkBacks
