Results 1 to 14 of 14
Amp help
This is a discussion on Amp help within the Audio/Video Electronics forums, part of the General Discussion category; I think my amp is a little dead. I have a simple set up in my truck, Sony Headunit, Infiniti ...
    Registered User 99Suburban's Avatar
    May 2005
    Wylie, Texas
    Amp help
    I think my amp is a little dead. I have a simple set up in my truck, Sony Headunit, Infiniti speakers, and a 10" sub with a 250 Watt amp. Lately though, my sub has been cutting in and out. When it cut out, it stayed off for a few minutes, and then it seemed to "try" to come back on. It would hit and then stop, hit and stop. Next day, everything worked fine. A couple days later, I put on some good heavy bass music and the thing pitters out again. And it doesn't seem nearly as powerful of a bass sound as it was before.
    Can amps start to lose power? It seemed the more I turned up the amp control on my headunit, the faster the bass disappeared and the set up stopped working.
    I hope everything I said makes sense. Any help would be greatly appreciated...
    Thanks.
    1999 Chevrolet Suburban K1500 4X4
    1998 Chevrolet C1500
    ***PICS COMING SOON OF THE 1998***
    Slow-N-Steady TigerEyz3's Avatar
    Sep 2002
    Smyrna, TN
    Re: Amp help
    Check your connections to make sure that something hasn't wiggled loose. If all is tight, check the power/ground wires as well as the speaker wires to make sure something isn't shorting out there. If all is good with your wires, then check the amp - if you've been running it hard (and possibly incorrectly ohmed ) for any length of time, it may need repair/replacement.
    Prov 3:5-6; Jer 29:11
    '99 2wd 4dr Tahoe:
    Mods list
    May 2005
    Wylie, Texas
    Re: Amp help
    I checked all the wires at the amp, at the speaker and there are definitely no loose wires. Also, with loose wires, it wouldn't lose power when I crank it up, it would lose power every time I hit a bump.
    Jan 2006
    MN
    Re: Amp help
    Does it only cut out at high volumes?
    May 2005
    Wylie, Texas
    Re: Amp help
    For the most part, yeah, I guess so. My headunit has a separate control for the amp volume and when I increase that the amp seems to give up slowly. It'll hit off and on and then just stop dead.
    It doesn't work at all now. I don't know...
    Jan 2006
    MN
    Re: Amp help
    Did it get hot when it went out?
    May 2005
    Wylie, Texas
    Re: Amp help
    The first day it happened, i smelled what I thought was something electrical, but I had my windows open and thought it was something from outside. I've been feeling it each time it's gone out, and I can't tell that it's any hotter than normal...
    May 2005
    Wylie, Texas
    Re: Amp help
    Today I tested it a little. While I had the volume down everything seemed to work fine. I turned up the volume a little on a radio station (relatively weak signal) and the sub was punching lightly. After that, I turned on a CD with some good bass line and the the sub cut out almost immediately. This happened a couple times on the way home.
    To me, I think the amp is shot...
    Jan 2006
    MN
    Re: Amp help
    Could be, either that or you subs all of a sudden have a much lower impedance for some reason than they did before. I assume this has worked for a while? What kind of amp is it?
    May 2005
    Wylie, Texas
    Re: Amp help
    It's been working for several months now. I bought the amp off Ebay, used, and the box I bought from Circuit City. (See link below) The amp is a Sony Xplod 250 watt 2 channel amp that is pushing a Kicker 10" Comp Subwoofer/Enclosure Package (07TC104)(link).
    http://www.circuitcity.com/ssm/Kicke...oductDetail.do
    It happens everytime I turn the volume up, the amp starts cutting out. It's almost as if it gets weak. It'll hit and then fade out.
    Jan 2006
    MN
    Re: Amp help
    I'd stop worrying about it and get a new amp as it would be worthwhile to replace it anyways.
    May 2005
    Wylie, Texas
    Re: Amp help
    I just wanted to update you, if you still care. It's actually kind of stupid.
    I pulled all the wiring for the amp and sub and found that it was all okay. I took another amp from another car and tried it out and the same thing happened. So, not the amp. I looked harder at the wiring and then decided that i should look at the power wire where I had it connected to the battery. It was burnt and in very bad shape. Go figure, last thing I look at. I've never had an issue with how I've connected the wire to the battery, but for some reason it didn't like it this time.
    Oh well, I spent a long time reinstalling everything and connected it to the battery via an extended post and everything works fine now. Thanks for the help :)
    247KneeDragger indelible5's Avatar
    Nov 2005
    So.Cal
    Re: Amp help
    '99 K1500 ECSB 4.8 NBS Z-71, 285/75/16 BFG A/T KO, 1.5" TB Crank, Premier 880PRS, DLS R6A's, DD1508 x2, DD C2a x2
    '03 GSXR.1000 - Canyon Carver
    '01 GSXR.750 - Road Race Bike (For Sale)
    '82 XR80 - Pit Bike
    like a rock
    Nov 2006
    Chicago area
    Re: Amp help
    my 10" did that i replaced the 20 amp fuse now it is fine
