Results 1 to 4 of 4
Issue with kicker amp!
This is a discussion on Issue with kicker amp! within the Audio/Video Electronics forums, part of the General Discussion category; I got my 750.1 today and its having issues. The leds are flashing red green over and over again. I ...
    Registered User Aarolar's Avatar
    Jun 2007
    SE Georgia
    I got my 750.1 today and its having issues. The leds are flashing red green over and over again. I have checked voltage and am getting like 15.4 volts with the truck not running and I set the gain with the tutorial at the top of this forum it all checks out. Also the resistance on the subs is right also at 1.9 ohms. The only thing is its kinda hot. I have read the instructions and it says nothing about a flashing led only a red and green one. So whats the deal is it broke and need sending back?
    '01 1500 ECLB Z71
    One time I thought I saw the light at the end of the tunnel, turns out it was just a train...
    1999 Z71 w/ system thumpintruckred's Avatar
    Aug 2006
    Indiana and Iowa
    Re: Issue with kicker amp!
    That is kinda high voltage, but should not be a problem.
    My 850.4 runs SUPER hot, and I know others do as well. Do you have it grounded well? Check remote wire?
    Jun 2007
    SE Georgia
    I just got off the phone with Kicker Tech support and we have pretty much narrowed it down to a bad amp. It must have had a loose ground or something is what they said. And I checked again and the voltage checked out as 12.3 so I was wrong on that I don't know what I was reading before Anyways kicker said to send it to them with an invoice from HiFi and it would be under warranty soo what ever I guess it will be another two to three weeks before I get things going. Anyone ever got in contact with HiFi before? I would like to call them and let them know I have a bad amp but they won't answer the phone.
    '01 1500 ECLB Z71
    SLACKIN' CARLISLE BISH Jokeman's Avatar
    Oct 2001
    Boston
    I had the same issue. I unplugged mine for a few days and it decided to work again. I'll never cheap out on amps again.
    If its loud, fast and runs on flammable liquid......count me in.
    Built LQ9...blah blah blah
