Results 1 to 9 of 9
Amp for Dayton HO's?
This is a discussion on Amp for Dayton HO's? within the Audio/Video Electronics forums, part of the General Discussion category; I just ordered a pair of 10” Dayton HO’s and I am looking for an appropriate amp to push them. ...
    GO GATORS!!!!! rukkuzz71's Avatar
    Feb 2007
    Gainesville, Florida
    I just ordered a pair of 10” Dayton HO’s and I am looking for an appropriate amp to push them. My amp budget is firm at $350 and I plan to wire them in parallel for a 2 ohm load. I am currently looking at the Hifonics BXi2008D and the Kicker Zx1000.1. They are both comparatively priced. The Hifonics amp claims 1300w RMS at 2 ohms and the Kicker at 1000w. I know the Hifonics is overrated on output and the Kicker is probably underrated so the decision is probably a no brainer. I just wanted to get some opinions before I pulled the trigger. Which one would you choose or are there other options I haven’t found? Thanks for your help.
    Shawn
    00 ext cab w/3" body lift on 33" Nitto Terra Graplers. 10" Dayton HO's, Kicker zx1000.1, Goldwood GW-S650/4 6-1/2's, Hifonic Txi 6008
    Sep 2006
    Charleston, SC
    Re: Amp for Dayton HO's?
    Those Kicker's are usually underrated. Go Kicker
    Jun 2006
    Hot Springs Arkansas
    First off what size enclosure are you putting the daytons in. Ported or sealed? These subs are very enclosure dependent for power handling.
    Read this before deciding on enclosure size
    http://www.diymobileaudio.com/forum/...ad.php?t=17889
    This sub shines in roughly .3 cube sealed net.
    09 avalanche ltz white keeping it stock
    Feb 2007
    Quote Originally Posted by sqsilverado
    I plan on a sealed, down firing eclosure, under the rear seat.
    Jan 2006
    MN
    Out of those choices, the Kicker is a no brainer no matter what the enclosure is. They will however work stellar under your seat. Nice choices!!
    Jun 2006
    I would go with the kicker. Imo it is a better amp. Any kicker amp I have ever owned was beat on and never lost a beat. Put those subs in about .3 to .4 net and don`t look back. Should sound great. I have the same subs and am putting them in .5 gross just wish I had time to finish the install.
    Feb 2007
    Kicker it is. Thanks for your help guys!
    shawn
    Feb 2007
    Is gross and net referring to before and after sub displacement?
    Jun 2006
    Correct, gross is the enclosure itself and net is the enclosure with the sub installed. Make your enclosure .5 to.55 gross and all is good. I would suggest making it a little big maybe .7
    or .8 and use 2 by 4 blocks to get the sound right for you.
