man dont even deal withh them they sell counterfit stuff that dont work half the time!!! i have that same sub your talkign about though. what are the dimensions?
This is a discussion on quick question within the Audio/Video Electronics forums, part of the General Discussion category; Does anyone know if the dimensions of the 06TS10L74 on sonicelectronix.com are correct? they seem way too big and on ...
Does anyone know if the dimensions of the 06TS10L74 on sonicelectronix.com are correct? they seem way too big and on kickers site the new 08 version has what seems to be right sizes.
2002 Silverado 1500 4.3 V6 Vortec
Tint/Magnaflow Exhaust/Kicker Sound/Dynamat In Doors
2006 Silverado 1500 LT 5.3
All Stock
gallons per mile...
nvm but the dimensions are correct. i just checked them.
gallons per mile...
they do good bussines. i have ordered from them before. so the correct dimensions are too big to fit in my single cab?
All Stock
i have those subs in my 98 reg cab...behind my seats and have plenty of room to lay back still.
gallons per mile...
I've delt with them before and never had a problem...
akjay907, what amp are you running those on?
All Stock
akjay907, what amp are you running those on? do they hit hard and loud and are they worth the money?
All Stock
add at least 500 watts to each, and you'll like them :)
I'm planning on a 900 watt kenwood. ill just have to turn the gains down a little. the 4 ohm model can be wired parrallel to make a 2 ohm load, am I correct?
All Stock
if it's a 4 ohm, that is 4 ohm at the cup...
what exactly does that mean?
All Stock
what exactly does that mean?11
All Stock
Yes, 1 4 ohm dvc can be wired in parallel to 2 ohm.Originally Posted by millerpro
00 ext cab w/3" body lift on 33" Nitto Terra Graplers. 10" Dayton HO's, Kicker zx1000.1, Goldwood GW-S650/4 6-1/2's, Hifonic Txi 6008
From his posts though it looks like an SVC 4
Originally Posted by ///M5
sonicelectronix has it listed as a DVC 4![]()
it come sin 2 ohm and 4 ohm, just pick which one you need for your amp.
Indeed. The OP stated 06TS10L74 which both of us know is 4ohm.Originally Posted by Polecat
