Results 1 to 4 of 4
lights dimming/voltage guage low
This is a discussion on lights dimming/voltage guage low within the Audio/Video Electronics forums, part of the General Discussion category; I have a small system running 400 watts. Afeter a little while of playing i can see my dash lights ...
    Registered User mrteacha's Avatar
    Jul 2005
    ny
    I have a small system running 400 watts. Afeter a little while of playing i can see my dash lights beginning to dim and the voltage guage on the dash goes dangerously low. In the future I plan on running a bigger system totaling about 1200 watts. To help remedy my issues should I: (A)do the big 3
    (B)High output alt.
    (C)2nd battery
    1992 2 dr FS Blazer 4x4
    Cause Finished is Boring LSx2dr's Avatar
    Nov 2007
    Tennessee
    Re: lights dimming/voltage guage low
    I would start off with the big three,(being the cheapest) and then see if that helps out at all. And then after that if it doesnt help move on to a better battery and then bigger alt. The big 3 helped out alot on mine.
    Dec 2007
    Atlanta, GA
    Quote Originally Posted by YUKNTUKN22S
    ^i 2nd that...big 3...then get a BETTER battery first....and additional one would only strain teh alternator more if that is what the problem was.
    Jan 2006
    MN
    400w should NOT cause a dimming issue, my guess is your gains are WAY out of whack
    I have absolutely no dimming with the big 3 only and I am running JL amps (1000/1 450/4) which are current hogs.
