Results 1 to 3 of 3
what amp to power 2 12" in ch kickers?
This is a discussion on what amp to power 2 12" in ch kickers? within the Audio/Video Electronics forums, part of the General Discussion category; Lookin gfor the right amp to power 2 12" shalow mount kickers, dual 4 ohm at 800 watts peak and ...
    Feb 2007
    New Jersey
    Lookin gfor the right amp to power 2 12" shalow mount kickers, dual 4 ohm at 800 watts peak and 400 watts rms. I dont want to break the bank on an amp, i was lookin gat power acoustic and others, im just not sure how much to run to them because i dont want to blow them, help would be appreciated!!
    fortplainman
    Guest
    Re: what amp to power 2 12" in ch kickers?
    dude stay with kicker on this one and go for the zx750 thats solid enough to power those and you would be really happy with it. Your setup is what I have been looking at but just 10's to put underneath my extended cab seat. It might be a little pricey, but you get what you pay for from kicker.
    Dec 2007
    Pinnacle, AR
    Quote Originally Posted by fortplainman
    the pair of subs will present a final load of either 4 ohms or 1 ohm depending on how they're wired to NO on the kicker amp.
    http://www.woofersetc.com/index.cfm?...roduct_ID=4871
    cheap, reliable, but will definately suck more current than a class d amp. seems like there aren't nearly as many 1 ohm stable amps out these days for some reason. either way as a rule of thumb i refuse to take ANY amp below 2 ohms.
    06 SCSB Sierra SLE
    Alpine 9833*PG Xenon 100.4 & 400.1*PG tld66 linedriver*Focal Polyglass mids*Morel mdt29 tweets*RE SE12 in downfiring console built by xplicitACTSStupid loud and no distortion is what it's all about
