Results 1 to 12 of 12
New Orion 5000D Internall Wired in Parallel? Huh?
This is a discussion on New Orion 5000D Internall Wired in Parallel? Huh? within the Audio/Video Electronics forums, part of the General Discussion category; I have the new Orion HCCA 5000D and it says in it's manual that it's internally wired in Parallel, but ...
    Obama/Biden 2008 sbc2008's Avatar
    Feb 2008
    San Antonio, TX
    Question New Orion 5000D Internall Wired in Parallel? Huh?
    I have the new Orion HCCA 5000D and it says in it's manual that it's internally wired in Parallel, but give no explanation. What does this mean?
    EDIT: Will this keep me from running Subs in a Series?
    (Sold!)'97 Chevy RCSB
    Vortec 350|Vig 2600 Stall|Vette Servo/4th Servo|TransGo HD2|Bullet Proof 4L65E|4.10s|JBA Short Tube Headers|Westers 91/93|K/N CAI|Dual Magnaflows|Audio: 12" Memphis M3 2.2 cuft Ported to 30hz
    Jan 2006
    MN
    Re: New Orion 5000D Internall Wired in Parallel? Huh?
    It won't keep you from doing anything external. They must be trying to say that it is 2 2500's wired together internally; however, your description is really short so it is rather hard to make anything out of it.
    Feb 2008
    San Antonio, TX
    The Orion HCCA-D1200, HCCA-D2400, and HCCA-D5000 amplifiers offer two positive and two negative output terminals for ease of connecting the speakers to the amplifier. Sincethese are mono amplifiers, the speaker connectors are paralleled internally. Each amplifier is stable to 1W.
    That's what the manual states...
    EDIT: These are Mono Channel Amps
    Jan 2006
    MN
    Ah, then it is just telling you that there are extra terminals to wire your dvc sub up to. They are internally connected, ie in parallel. It makes no difference to how you wire your subs.
    Jan 2006
    MN
    *I assume you mean stable to 1ohm and not 1w
    Feb 2008
    San Antonio, TX
    Quote Originally Posted by ///M5
    Well that's how it was directly from the manual lol
    mud makes me horny
    Jan 2006
    Peoria Illinois
    My guess would be its 2 2500d strapped from the factory
    Feb 2008
    San Antonio, TX
    Quote Originally Posted by jerz02
    lol that's the samething that M5 said....
    Σ∫Chevy dx Undisputed King's Avatar
    Sep 2007
    Cen Cal High Rollin'
    no its not that, its the second thing M5 said, its basically one set of outputs + and - are y'd off to make two sets of outputs + - and + - gives you ease of wiring.
    2000 Silverado Ext -
    10" Whiplash Susp, 20" KMC Rockstars, 36" Swampers, Super 40,Panasonic HU, PG RSD, JBL Px300.4, AQ HDC315 3.6cu ft @ 38Hz, Crunch GP3000D, 1/0 & 4 AWG, Deka Grp 31
    2001 Yamaha YZF-R1 -
    Leo Vinci Slip-on, Hot Cams, K&N, +3T Rears
    Feb 2008
    San Antonio, TX
    so what your saying is that the Outputs themselves are wired in Parallel for the amp itself. In other words giving you two outputs for the ease of installation and combining the two outputs internally to make them one. I think I get it know...
    Jan 2006
    MN
    Quote Originally Posted by sbc2008
    Which is actually the second thing I said. I doubt it is two 2500d's strapped as they couldn't then take 1ohm, that was my guess before you gave us details.
    Sep 2007
    Heres a simplified diagram of your amplifier. The outer rectangle is your overall amplifier. The inner gray rectangle is your sub power source, then you have your two leads comming off of it, and y'ing off so you have a total of 4 outputs comming out of the amplifier.
