Results 1 to 7 of 7
Is my component blown?
This is a discussion on Is my component blown? within the Audio/Video Electronics forums, part of the General Discussion category; Is my component speaker blown? It started acting up a few days ago. It makes sound but hardley any sound. ...
    Registered User justinp95's Avatar
    Jan 2005
    Texas
    Is my component speaker blown? It started acting up a few days ago. It makes sound but hardley any sound. The amp is only like 60 watts...
    05 F250 4x4 King Ranch
    1998 Tahoe 4x4 33" SSR's
    SOLD:
    *04 F250 4x4 CC 6.0, 6.5" Pro Comp, 37" Kuhmos & 20" Rockstars
    *2500HD 4x4 CC LB7, 305 SSR's, MBRP, Quadzilla
    *2500HD 4x4 CC 8.1, Ranch Hand
    *1500HD 4x4 CC 6" Superlift, 37" SSR's, 16x10s, Flow & Ranch Hand
    *Tahoe 4x4 6.5" DC, BL, Boggers
    Σ∫Chevy dx Undisputed King's Avatar
    Sep 2007
    Cen Cal High Rollin'
    Re: Is my component blown?
    Well look at it, smell it. If the cone is busted then obviously you need a new speaker. If it smells burnt then your coil is fried. If its none of those then I would suspect the wiring not getting through to the components. My speakers would make funny noises once in a while, like ugly static noises, and popping noises, and they would play very lightly, and i confluded it was my amplifier making the speaker do funny things, it had to do something with the crossover switch, cause when i wiggled it it would clear up the signal. So just start from the source and work your way through
    2000 Silverado Ext -
    10" Whiplash Susp, 20" KMC Rockstars, 36" Swampers, Super 40,Panasonic HU, PG RSD, JBL Px300.4, AQ HDC315 3.6cu ft @ 38Hz, Crunch GP3000D, 1/0 & 4 AWG, Deka Grp 31
    2001 Yamaha YZF-R1 -
    Leo Vinci Slip-on, Hot Cams, K&N, +3T Rears
    damn you all... framedraggin'94's Avatar
    Mar 2006
    Central, LA
    check ur crossovers
    Jan 2005
    Texas
    Ok, Ill check the crossover.
    SOLD:
    Jan 2005
    Texas
    I checked the cross over, but everything is tight and good to go...what now?
    SOLD:
    is laying rocker drpd93's Avatar
    Sep 2008
    Ithaca, MI
    sure the amp's putting out? try it on a different speaker.
    Bag. Drag. Get Layed.
    Jan 2005
    Texas
    Hmmm, good idea. Ill swap the wires and see if that changes anything.
    SOLD:
