i know summit racing has pressure monitors but idk if they let you change the pressure
This is a discussion on Tire Pressure monitor? within the Audio/Video Electronics forums, part of the General Discussion category; Do you guys know where to buy one of those hook ups where it allows you to see the tire ...
Do you guys know where to buy one of those hook ups where it allows you to see the tire pressure in your front and rear tires and lets you remove and add air from inside the cab *kinda like what the H1 hummers have* Any leads would be nice
2000 Suburban 2500 LT: 9.5 susp, 3 body. rear lift is combo of shackle flip, drop spring brackets, and 2" block. ORD ubolt flip kit. Bilstein 5150 piggy back shocks duals up front singles in rear. 36x15.50 MT baja claw, DC1 wheels, ORU polished differential cover. k&n intake, 4" Magnaflow catback
good luck retro fitting a central tire inflation system. Probably not going to happen unless you are really good on a cnc and are ready to make some new hubs. The air passage goes through the center of the hub. But I believe the half shaft goes into a gearing mechanism. Were the shaft enters the top then power is transferred to a lower spot on the hub through gearing and then exits out to the wheel. This makes it possible to run a air line through the center of the lower hub.
Like unimog hubs
1994 ECSB SAS 7" lift, satin black h2 wheels, 36" IROKS, 98 Interior
Built 383 and Built 4l60E
2007 Yamaha midnight warrior
yeah I was just curious what it was called... didnt plan to put it on my rig
http://store.summitracing.com/partde...5&autoview=sku closest thing i know of
