Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Amp placement
This is a discussion on Amp placement within the Audio/Video Electronics forums, part of the General Discussion category; So I finally got my TS-C720PRS in the mail today. I had a line on an amp but the deal ...
    You ought to listen to me Kazyn's Avatar
    Nov 2007
    Dallas, Texas
    Amp placement
    So I finally got my TS-C720PRS in the mail today. I had a line on an amp but the deal fell through.
    I'm still looking at getting a ZX250.2 but before I go and find a place to shop, are there any last-minute suggestions? I am aiming for around 85-100w per side.
    To get to my placement question, where is the usual spot for single cab trucks? I was thinking under my center seat/console but I didn't know if it'd get too hot there. Is heat an issue with these small amps?
    Hello, My name is Garrett.
    A jest breaks no bones. BOTMAN's Avatar
    Jul 2008
    Norman, Oklahoma
    Re: Amp placement
    That amp with be fine. Then mount the amp on the back wall of the cab.
    2003 20th Anniversary GTI
    1982 2wd Blazer
    Flickr
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    With what? I'd rather not put holes in my truck, plus I have my books/backpack/jacket/etc back there all the time, I'm sure if I didn't build a box over it that the wires would get smashed up within days.
    Registered User aaronb's Avatar
    May 2005
    sparks,nv
    Re: Amp placement
    you could glue a piece of mdf or plywood to the back of the cab and then screw the amp to that.
    98 stepside:hp 44,14bolt, 5.13's, 39.5" rockers on 15x12 bart wheels, doug thorely tri-y's,
    Jul 2008
    Norman, Oklahoma
    Re: Amp placement
    You could mount it under the seat if you want to. But the usually spot is on the back wall. Most people glue mdf onto the back wall then screw the amp on to that.
    1982 2wd Blazer
    Flickr
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    Interesting.
    I would have to build a box around it though, cause I know it'd get trashed any other way.
    Is there enough room underneath the center seat/console? I haven't measured anything yet, just intrigued and bored at work.
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    I'm now looking at getting the Pioneer GM-5400T over the ZX250.2 simply because I've always been a fan of pioneer and the rest of the system is pioneer. Any comments on this amp?
    Also.....what wiring kit would I use for this? Should I just make my own kit or buy an actual kit?
    Jul 2008
    Norman, Oklahoma
    Re: Amp placement
    Im pretty sure it would fit under the seat. I can tell you tomorrow when my ZX250.2 comes in.
    1982 2wd Blazer
    Flickr
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    Quote Originally Posted by V6rado94
    sweet thanks.
    Registered User FastBlak's Avatar
    Sep 2007
    Arizona
    Re: Amp placement
    You wont be able to fit that under the center seat. Maybe if you jam it in there but thats a no go!
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    Quote Originally Posted by FastBlak
    What if I lifted the console about an inch? Is that or ?
    Forum Leader AuburnTruck93's Avatar
    Sep 2007
    Georgia
    Re: Amp placement
    if you lift the console your always gonna be annoyed with how much higher it is. just pull up your carpet on your back wall, liquid nails the mdf to it and then screw the amp to that. just remember its there and throw your stuff in the other side. if you build a box around the amp its going to trap heat and fry the amp.
    SOLDFlowmaster Super 44, no cats, TBIchips tune, e-fans, underdrive pulleys, Ultimate TBI.
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    I'm actually kind of annoyed at how low it is right now...I'm 6'5" so if I raised it a little I think I'd actually like it more.
    I'll probably put it on the driver's side back wall, cause usually I throw stuff in the passenger side. Maybe I can put an upside down "L" around it to block it off from the avalanche of sh*t in the back of my truck.
    What about the amp kit? I went to Best Buy (I know, rape city for the wallet) and they had a rockford fosgate kit that used 8ga wire. Would something like that work? I'm sure wire is wire, but I don't know what I'm doing
    Sep 2007
    Arizona
    Re: Amp placement
    Well if IIRC the center seat bolts into the same holes as the regular seats. And the regular driver and passenger seat sit on top of the mounts for the middle seat. SO i think you would have to lift ALL the seats and not just the middle. Unless you put the mounting brackets on top of the driver and passenger brackets and put some sort of spacer on there. idk if that would work, but it would look kinda silly being taller than the other seats.
    Burgandy Bullet
    Jun 2008
    Nelson, BC, Canada
    Re: Amp placement
    for a 250.2 8ga would probably be okay but if you ever want to throw in a bigger amp your going to want to go 4ga for sure not only will it sound better theres a better chance of you not causing an electrical fire =p but if your gonna stick with the 250.2 8ga will be fine
    97 1500 5.7l 350
    300,000km+
    and
    2005 1500 5.3l
    Sep 2007
    Arizona
    Re: Amp placement
    And as for the wire. check out knukonceptz.com ive always been very happy with there wire and prices. Or even look at welding wire, its even cheaper but not as cosmetically appealing.
  17. #17
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    Something like this? Looks pretty good to me.
    I have decided against the whole seat thing, wayyy too much work and I think you're right on the mount issue FastBlak...
  18. #18
    Jul 2008
    Norman, Oklahoma
    Re: Amp placement
    Yep. The 250.2 recomments 8ga. KnuKnocepts are great people to order from
    1982 2wd Blazer
    Flickr
  19. #19
    Nov 2007
    Dallas, Texas
    Re: Amp placement
    Sweet. I'm gonna start the ordering process early next week
  20. #20
    Sep 2007
    Georgia
    Re: Amp placement
    I would recommend spending the extra 12 dollars on 4 gauge in case you want to upgrade down the road. if you spend 15 on that and decide to upgrade your going to spend 30 on a 4 gauge kit, then you will be out 42 bucks
