Is the particle board permanent?
I'd change that to MDF a.s.a.p.
Cool idea tho.
This is a discussion on nbs reg cab 3 jlw3 10's build within the Audio/Video Electronics forums, part of the General Discussion category; Ok so i got tired of my old crappy pioneer tens and a make shift box that we kinda threw ...
Ok so i got tired of my old crappy pioneer tens and a make shift box that we kinda threw together so we started playing around... i aquired 3 jl0w3's. we tried to do the behind the seat thing, but since i am tall and fat it aint working. So out first kinda goof off idea was i took the ported console box tthat i made like 6yrs ago that i had in there with the pioneer 10's and we basically cut another hole in it... i sounded...ehh ok it db'd at a 133.7. it looked like sh*t and we wanted to do soemthing different. pics of rigged setup....[IMG][/IMG]
with the sub cut in...[IMG][/IMG]
so what we have come up with is a downward firing center console that will hold all 3 subs.. it is ported and tuned at 34hrz. we got it al cut and are waiting for the glue to dry. so i figured that i would post pics and get some feedback...
[IMG][/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
Fatkid Racing...
02 rcsb 4.3 5sp 20" daytons with 255/45 toyo proxes, no cats with cherry bomb chambered muffler, 4/6 drop ,HD hood and Grille, hid's ,anzo taillights ....
http://www.ohiofullsize.com
Cool idea tho.
2003 Ext Cab Z71 :fsc:
its particle....they were out of mdf.. we just wanted to see how it would sound...then i will build a permanent one..
Fatkid Racing...
It is finally all glued up and sealed... turned out really good...tonight i am going to cut holes in the bottom and put the legs on, and then test it out... lemme know what ya think..
[IMG][/IMG][IMG]
[/IMG][IMG]
[/IMG]
just some random pics from the build...[IMG][/IMG][IMG]
[/IMG]
Fatkid Racing...
I see your missing a rear bumper, I will get that roll pan to you ASAP man.
But the box looks great! Great work man!
♠ Magnaflow ♠ Rough Country 3" ♠ 33" Cooper STT's ♠ Blackbear ♠ K&N ♠ Keystone Hood ♠ Carriage Works ♠ Paint ♠ 6000K HID's ♠ 35% Tint ♠ XD Hoss's ♠ Bedrug ♠ Smoked Tails ♠XBL: ll U MAD BR0 ll
yeah i got this guy who has a rear bumper...just real hard to get a hold of....
Fatkid Racing...
You will have port noise.
port noise?
Fatkid Racing...
Audible noise coming from the port, like whistling or any other sound not created by the sub itself.
that port is to spec.. if that is what u are comenting on...other than that feel free to sahre any thoughts or concerns..
Fatkid Racing...
What are the box specs? Gross volume? Port area? port length?
And the port noise will come from the front baffle extending over the front of the port, it creates a very tiny amount of disturbance but impacts the entire ports airflow. The noise might not be bad, but there will be atleast a small amount of port noise.
i doint remember all the specs off hand i got them at the house...the port is to jl spec on that. hey called for a 4 inch round port nine inches long. that is the square equivilent.. the front baffle doesnt stick over the edge of the port. besides that is a down firing box. the port is on the top....?
Fatkid Racing...
Well whatever that lip is that sticks above the port. Also you do realize that port tuning is also dependant on the overall internal volume? That is to say, if the spec says that you need a 4 inch round port nine inches long with an internal volume of 2 cubes, the same port with 2.5 cubes will yield a different tuning frequency.Originally Posted by sgtshaft919
the box was built from dimesions on blaubox. it is built and designed for 39 hz
Fatkid Racing...
ok finally got it all sealed up and installed last night at about midnight.. sounds amazing... very clean deep punchy bass. we metered it and was like 134 at the dash and 148 at the port. fitment was awesome.. i just thinki need more power...lemme know what u think i should finish it in...
[IMG][/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
Fatkid Racing...
you dont have leaks in that box? some of the cuts didnt look straight in the test fits.
good design, I would cover it in vinyl if you can get it.
SOLDFlowmaster Super 44, no cats, TBIchips tune, e-fans, underdrive pulleys, Ultimate TBI.
no air leaks....came together awesome...if i were to lay viynl do i have to lay something underneath it?
Fatkid Racing...
I would recommend putting a thin padding on it first before wrapping it. Looks like a nice build btw!
is your port facing foward or backwards?...I have going foward, nice build
it is at the back of the cab facing upwards...
Fatkid Racing...
