Number 1 listen to NOTHING about what car audio shops or stores say. Usually they are less informed then you and are tryin to sell the most expensive unit. Im not sure about that unit, but i know on some you can use a external hard drive set up for music. Some also allow you to insert a SanDisk card loaded with music. ill check out the z3 n see what i pull up
LinkBack URL
About LinkBacks
, Nelson tune, JBA Shorties, 80mm BBK Throttle Body, 6" Tuff Country lift, Toyo MT's 35's rolling on 20" MHT Fuel Hostage Wheels, Eclipse Avn62D Navi with 2 small 8's
