Results 1 to 19 of 19
shock sensor for a viper alarm
This is a discussion on shock sensor for a viper alarm within the Audio/Video Electronics forums, part of the General Discussion category; today i installed a viper 350hv in a friends 04 ford f150. everything works good except its not nearly sensitive ...
    Registered User LOWRNU's Avatar
    Jan 2007
    oklahoma
    everything works good except its not nearly sensitive enough.
    Its a service truck so he has 3 tool boxes in the bed with lots of expensive parts in them.
    Do I need to install a 504c dual shock sensor (will that be good enough) or what would be good for this
    Formerly inside your MOM. RoLL1n D4rK's Avatar
    Jan 2008
    B1ow1n B1aCk Sm0k3 ThRoUgH MeMpHiS, T3NaK3y
    Re: shock sensor for a viper alarm
    where did u mount the brain at?
    02 DMAX!!!!!! 6" fabtech kit on 315/75/16's AFE intake and 4" straight pipe
    Registered User Dyabolical's Avatar
    Apr 2008
    Vinita, OK
    Is it a service type box bed or like the lockable tool boxes?
    Jan 2007
    oklahoma
    its behind the cluster, for now its zip tied (dangling) because when we mounted it we couldnt get the alarm to go off at all(except for when the door pin would set it off)
    now it go off if you really bang around on it
    Jan 2007
    oklahoma
    Quote Originally Posted by Dyabolical
    just the lockable toolboxes one in the front and 1 on each side
    Apr 2008
    Vinita, OK
    If you are worried about someone getting in the tool boxes, use a trip switch.
    Lost before Dawn CustomChevyGuy's Avatar
    Aug 2004
    305, South Fla
    i was thinking about getting the shock sensors mounted around the rims in case i get jacked like loud...but the shop i had do the work didnt have them in stock
    Quote Originally Posted by bhookxen
    sometimes bad-assery takes time
    71 Chevelle 454
    03 rcsb, 06 clip/tails, HD hood, 22's, Esky handles, Alpine head unit, 5% tint, clear corners, 8K HID's, FM50, 2" rear drop, debadged, BlackBear Tuned!
    Jan 2008
    just wire up some pin switches to the instant trigger coming off the brain. i belive it is the blue wire.
    Jan 2008
    Quote Originally Posted by CustomChevyGuy
    why dont u just get a digital tilt sensor?
    Jan 2007
    oklahoma
    where can i get them?
    sorry for the dumb questions Ive never messed with alarms so this is all new to me
    Jan 2008
    Quote Originally Posted by LOWRNU
    the alarm should have come with one already but just look for any audio shop near you. you will also need the brackets for them. we sell the pin switches for like 5 bucks a piece.
    Jan 2007
    oklahoma
    nope it didnt come with any we ordered 3 alarms and they all have the same stuff (harness,led,antenna,brain) its got a plug for the 4 pin shock sensor thou
    Jan 2008
    i could be mistaken. idk i do so many alarms i cant remember. and audio shop should have em just go in and tell em what your trying to do. they should give u some pin switches and the brackets for em. i have also used magnetic switches on toolboxes as well.
    Jan 2007
    oklahoma
    Quote Originally Posted by RoLL1n D4rK
    ok ill check with them, thanks.
    what about the 504 shock sensor is that a good investment as well?
    does it make a big diff?
    Jan 2008
    no problem.
    we have added just a stand alone shock sensor on work vans and such. just extend the wires and make your runs.
    i would try and mount the brain to a main factory wire harness or a piece of metal tubing.
    i usually mount mine behind the headlight switch. and it always seems to work out fine.
    Registered User malibujason79's Avatar
    Oct 2008
    Dayton Ohio
    Would the 508 dual zone proximity sensor work in ths situation?
  17. #17
    Registered User FastBlak's Avatar
    Sep 2007
    Arizona
    I would not recommend the prox sensor. They false ALL the time and are affected by weather, tint, etc....kind of a headache. As everyone recommended id throw a pin in the door of each toolbox and maybe the shock sensor behind the tailight if there is access to the bed.
  18. #18
    Jan 2007
    oklahoma
    ok we are also installing one in a box truck, he has problems with people cutting his gas line a stealing his gas
    what do you think about installing the 508d in this.
    They are usually parked by themselfs at his shop.
    I figure that will be the only way to prevent people from doing this
  19. #19
    Sep 2007
    Arizona
    You can try but they seem to fals all the time. Anytime i have ever installed one for a customer i really try to have them go another route. But if theyre set on it i will show them where it is mounted and ill adjust it at the shop but after that theyre on their own, and they can adjust it themselves becasue itll never be right. They come back every week for adjustment
