Results 1 to 11 of 11
Bazooka tube/s or box for crew cab???
This is a discussion on Bazooka tube/s or box for crew cab??? within the Audio/Video Electronics forums, part of the General Discussion category; Would it make sense to put 1 or 2 maybe 8" or 10" bazooka tubes under the rear seat of ...
    Jun 2009
    Encino, CA
    Would it make sense to put 1 or 2 maybe 8" or 10" bazooka tubes under the rear seat of my 05 crew cab or should I stick with a box? I'm trying to achieve as much bass as I can and also the best quality bass. Any ideas or advise? Thanks
    Aug 2006
    norton,ma.USA
    Re: Bazooka tube/s or box for crew cab???
    i have an extra cab and one 8" amplified tube was just right...the 10's were too much, for just a tube with a radio no amp's
    ATI-Procharger D1-SC with a 3.100 pulley, 454 Custom ported TB, One-Off Custom Edelbrock conversion MPFI w/60# Injectors, MSD, Billet MSD Distributor , Ceramic headers and Cat-back, with a Fully forged 355 short block, full roller motor, with .510 lift, trick flow 195 aluminum heads...
    Jun 2009
    Encino, CA
    i have a whole system i'm going to be putting in. would a box with 10's be right or tubes?
    thanks
    Forum Leader AuburnTruck93's Avatar
    Sep 2007
    Georgia
    your much better off with a box than tubes.
    SOLDFlowmaster Super 44, no cats, TBIchips tune, e-fans, underdrive pulleys, Ultimate TBI.
    Jun 2009
    Encino, CA
    2 10's firing down or up? Or 2 12's?
    Registered User atlninja82's Avatar
    Oct 2007
    Forsyth co, GA
    Quote Originally Posted by AuburnTruck93 View Post
    1993 chevy k1500,3 inch body 2 inch suspension, 35 bfg km2, 17x9 xd hoss, sundown saz 1500, 2 DD T1510's. murdered out
    xZoomerZx's 100th sig.
    Oct 2007
    Forsyth co, GA
    Quote Originally Posted by yoneytan View Post
    whatever you can fit. depends on how much bass you want
    A jest breaks no bones. BOTMAN's Avatar
    Jul 2008
    Norman, Oklahoma
    I like the idea of two 8's.
    2003 20th Anniversary GTI
    1982 2wd Blazer
    Flickr
    Oct 2007
    Forsyth co, GA
    two sundown e8's would sound good.
    Jun 2009
    Encino, CA
    I checked the specs for my subs and it says "Min Rec Sealed Box Volume (CU. FT., Liters) 1.25 " so I figure if I get a box with that much space the subs should hit good. Question is who makes a box fit for these subs? I will be using my current punch 450 to power the front and rear highs and i'll be getting a mono amp(old school punch) for my subs. Input??????
    Registered User aort's Avatar
    May 2009
    Indiana
    2003 K1500 5.3L
