Results 1 to 7 of 7
CD player jammed, but no CD in it?
This is a discussion on CD player jammed, but no CD in it? within the Audio/Video Electronics forums, part of the General Discussion category; Stock headunit in an 03. Took a CD out when the truck was off like I have many times. Went ...
    Registered Abuser
    Dec 2006
    St Louis, MO
    Stock headunit in an 03. Took a CD out when the truck was off like I have many times. Went to put in a CD later and it won't accept it and CHECK CD pops up.
    I can force the CD in there if I want, but I'm sure that will eff it up even more. This ever happen to anyone else? Is it ok to force it in since it wont snatch it up on its own?
    2003 Silverado Z71 4x4
    Stock as a rock
    Registered Abuser
    Dec 2006
    St Louis, MO
    Re: CD player jammed, but no CD in it?
    Anything?
    Stock as a rock
    May 2009
    Tucson, AZ
    hmm, sorry man never heard of that before.
    Registered Abuser
    Dec 2006
    St Louis, MO
    Last try...
    Stock as a rock
    Nov 2008
    Texas
    check your fuse under the hood.Just pull it out and put it back in.It will reset your head unit.Do you ever play burned cds in it?If so that is whats prob.wrong.My 2005 did it like 3 xs.
    Registered Abuser
    Dec 2006
    St Louis, MO
    Quote Originally Posted by poisonz28 View Post
    A lot of burned
    It reset my radio, but it still won't accept the CD. Once you try to put it in, the TRACK screen comes up, but nothing happens. Then CHECK CD comes up. Getting pretty aggravating.
    Stock as a rock
    Ryan
    Sep 2009
    Oklahoma
    I just got my 04 about a month ago. It had a kenny chesney cd stuck in it when i got it and had to use a pocket knife to push down the plastic thing thats spring loaded... put in a different cd and it still wont eject, just sounds like its chewin on it.
    2004 Silverado
    - bone stock 2wd ext cab v6
    1987 Bronco
    - 351w 33's glasspacks 7mpg
    2005 Escape
    - 4wd v6
