Page 1 of 2 12 LastLast
Results 1 to 20 of 23
metal sub box
This is a discussion on metal sub box within the Audio/Video Electronics forums, part of the General Discussion category; OK i dont post much mostly in the build section or street section. But the story is im redoing my ...
    Under the knife again still2hi's Avatar
    Jul 2006
    Niagara Area,Ontario
    metal sub box
    OK i dont post much mostly in the build section or street section. But the story is im redoing my audio and interior this year in the green truck. I am 6' 6" so the regular cab isn't the greatest choice but whatever i like the look of them. I am going with 6 inch Infinity Kappa component spreakers in the doors and 1 ten inch thin sub. I cannot put it behind my bench seat as i do not want my seat to be shoved forward at all. So my idea was to put in on the floor in the passenger side. I want to weld a box right to the floor because with steel i can get away with thinner material. If i use MDF i need half an inch which doesnt sound big but adds up. If i use 1/8" for the sides and top and use the cabfloor as the bottom will it rattle? Or sound crappy. Im going after quality sound this time around not just loud bass. Im over that phase lol. I would sound deaden inside the box obviously. Any comments or suggestions?
    Why leave it stock? Polecat's Avatar
    Oct 2001
    Stillwater, Ok
    Re: metal sub box
    custom center console?
    Locked and Loaded
    Feb 2006
    Ocala, FL
    Re: metal sub box
    I am not an expert, but I would assume if you used a thick enough steel that would not flex then it would be ok. Maybe even put some sound deadener on the inside.
    Ok, now for someone to chime in and say it is not a good idea.
    Selling my 2003 2500HD on 38s and 24s. Auction ends on 12/28, bid now.
    http://cgi.ebay.com/ebaymotors/?cmd=...#ht_653wt_1064
    Registered User FastBlak's Avatar
    Sep 2007
    Arizona
    Re: metal sub box
    I heard a box once that was metal. And i thought it sounded like garbage, maybe it was just that one but i wouldnt do it. Have you considered fiberglass?
    Registered User supraloud84's Avatar
    Aug 2006
    buffalo, ny soon to be ocala, fl
    Re: metal sub box
    As long as the metal is thick enough to not resonate I think it would be ok. Ive never attempted this though so Im not sure. As said above, I would definitely use sound deadener on the inside of the box
    mine:92 ECSB, 4/6 Static on 22's
    the gf's: 02 2500hd eclb (lift and wheels soon)
    Registered User 1Sick1500's Avatar
    Sep 2009
    Orlando, Florida
    Re: metal sub box
    i wouldnt advise it. my truch had three 8" JL audio w0's behind my bench seat and they sounded great. the only issue i ran into, was a location to mount my amps. which ended up under the seats. now i am preping my truck for a blow through into the bed with 2 L7 15's. wood would be the only material i use.
    Sep 2009
    Hermosa Beach
    Re: metal sub box
    Quote Originally Posted by Polecat View Post
    I second that idea.
    A metal sub box is a not great idea. I have heard about 4, even with 1/4in. steel it will still flex, rattle, and vibe even sound deadened. I just don't see any reason to take the time, effort and not removability option of fabing and welding in a metal sub box, when MDF seems cheaper, easier and better sounding. There is always the fiberglass setup as a option which also can look pretty bad-@$$ical is done right.
    I am currently working on making a fiberglass box for under the seat of my ext. cab. Which is well a messy process but will look awesome when finished.
    1995 Silverado Ext. Cab O.B.S. Black, currently under destruction, I mean construction. PArts waiting for install, 88-93 Caddy Tails, sir micheals relocator kit, tons of billet.
    R.I.P. 1994 Silverado Ext. Cab, caddy tails, shaved tail gate, 3/5 drop on 20 in. Boyd Smoothie 2's, WRECKED!!!
    Registered User Dyabolical's Avatar
    Apr 2008
    Vinita, OK
    Re: metal sub box
    Plate steel is a bad idea. The only way i see it working is if you brace it from the inside and that would be a nightmare. In this case it sounds like fiberglass is your friend.
    Jul 2006
    Re: metal sub box
    sorry missed the responses, the center console is out i have that now with a flipout screen and 10" between the seats. But i am switching to a bench now i don't like the look of the center console. I think MDF would work better but it takes up space. The material has to be thicker and i dont have a ton of room under the seat. Aren't SPL vehicles all metal or do they use rediculous thicknesses? I think i could make it fit with MDF tho, just means it will be tighter down there.
    Car Audio GURU 12VoLt ShOcKeR's Avatar
    Oct 2008
    Oklahoma
    Re: metal sub box
    It would work out ok if you just used them as tubs then fiberglass a enclosure into the tubs...
    Other than that I would go a more traditional route ... Like the consol..
    A jest breaks no bones. BOTMAN's Avatar
    Jul 2008
    Norman, Oklahoma
    Re: metal sub box
    Quote Originally Posted by still2hi View Post
    SPL vehicles boxes are wood and fiberglass
    2003 20th Anniversary GTI
    1982 2wd Blazer
    Flickr
    Registered User adamv7010's Avatar
    Nov 2008
    Mount Olive, NC USA
    Re: metal sub box
    i have seen a few guys do a plain install, simple design box of mdf or birch, and wrap the box in plate steel....in those cases it was only the cosmetic effect they wanted.
    2005 Crew Cab Z71- 6000k HID in lows and fogs, True dual exhaust,2.5" with exits past rear end.
    2005 Ext Cab Z71-T-bar crank, 295/70/17 Terra Grapplers,True dual exhaust, 2.5" pipe w/4" stainless rolled edge tips, 5% tint on all windows. HID Gate 8000k HIDS in lows and fogs
    Jul 2006
    Re: metal sub box
    well either way its gonna be covered with carpet... i can use MDF just thought it would be simpler to use steel... weld it in and done
    Oct 2006
    GALT, CALIFORNIA
    Re: metal sub box
    I think that if you're willing to do some fab work, you may be able to make a box under the dash, directly in front of the passengers feet area. It wouldn't be visible if you do it right. Just a suggestion.
    Proudly Canadian&Ford Guy sniper_101's Avatar
    May 2008
    SK, Canada
    Re: metal sub box
    I would suggest a fiber/plexi enclosure at the least, metal (all thicknesses) will resonate horribly. You could also consider a free-air sub . . .
    2000 Ford F350 XLT - SCSB, 4x4, 7.3L Powerstroke, 6-spd (twin stick)
    "It's not leaking oil, it's sweating power!"
    1988 GMC Sierra Wrangler Edition - 90,000km The Daily
    1994 Ford Ranger - In Progress - 408W/TKO-500 swap and much more
    2007 Suzuki DRZ-400SM
    2003 Sierra z71 LndscpIllusion's Avatar
    Mar 2008
    BC, Canada
    Re: metal sub box
    Quote Originally Posted by 92CHEYENNEon22s View Post
    Was going to suggest something like this. For instance... Take out the glove box and mold something in there. I wouldn't suggest metal because it would just resonate and sound like ****. See if you can make a really thin wedge box behind the fully reclined seat and if needed for airspace, go underneath the seat. Those shallow mount 10" subs can get surprisingly small, or you could run 8's as well, I've heard a few that pound extremely well.
  17. #17
    Jul 2006
    Re: metal sub box
    ya i thought about the dash but i dont want to cut up the dash too much right now... its supposed look look stock clean and painted, i dont want to go to crazy on anything right now because i will be building a dash one day then i can figure something like that out but until then i have to figure something out... thanks for all the suggestions.
    Any opinions on a quality shallwo mount sub? I was looking at MTX but not sure how there shallow sub would sound?
  18. #18
    Jul 2008
    Norman, Oklahoma
    Re: metal sub box
    What about a 8" in the doors.. you are building custom door panels anyways.
    1982 2wd Blazer
    Flickr
  19. #19
    Jul 2006
    Re: metal sub box
    the pods are already done tho lol for 6's and the speakers bought too
  20. #20
    Sep 2009
    Hermosa Beach
    Re: metal sub box
    Just go shallow 10's under the seats, or even some good 8's behind the seats, it will add enough low fill. If your truly set on going big, cut a port through, build the box, weld the steel over the box in the bed, to make it interior sealed with the cab.
    That would be pretty bad ass. Seen it done on a buddy's C-10 in highschool, it gives you room for your subs, and on top of that protects them from the rain because they are sealed inside the cab, techically.
