Page 1 of 2 12 LastLast
Results 1 to 20 of 25
need advice for putting battery inside of burban.
This is a discussion on need advice for putting battery inside of burban. within the Audio/Video Electronics forums, part of the General Discussion category; Hello. I want to put a 2nd battery in my truck where the rear HVAC unit is at. can i ...
    BNSF railfan csx7006's Avatar
    Jul 2009
    Amarillo
    Hello. I want to put a 2nd battery in my truck where the rear HVAC unit is at. can i do that or will that be a good idea. I want to run 0 gauge wire. Thank you
    Why leave it stock? Polecat's Avatar
    Oct 2001
    Stillwater, Ok
    Re: need advice for putting battery inside of burban.
    sure, you can place it anwhere you want, just make sure it's safely attached to the vehicle.
    Jul 2009
    Amarillo
    ok
    May 2009
    san bernardino ca
    yeah and make sure its a sealed battery also. If you looking for 0 gauge I got some knu flecks im selling also.
    Jul 2009
    Amarillo
    Quote Originally Posted by aviator08 View Post
    yes i am. The battery im getting is the red optima battery
    May 2009
    san bernardino ca
    id go with a XS battery instead but up to you.
    Jul 2009
    Amarillo
    what is knu fleck?
    May 2009
    san bernardino ca
    Jul 2009
    Amarillo
    what gauge is your wires? how long are they?
    May 2009
    san bernardino ca
    I got 2 runs one blue one black both are 25ft long
    Jul 2009
    Amarillo
    how much for both runs? What is the gauge? thank you
    UNDER CONSTRUCTION.......
    Nov 2003
    indiana
    so your going to remove your rear HAVAC unit to put the battery there? or does it not have the rear air unit?
    IMO if your going to pull the unit out then i wouldnt, i would stick the battery up under the truck or another spot inside the truck.
    removing the air system has coolant lines and regrigerant lines as well, as well as hurting the valve of the truck when you do sell it without any rear air system.
    Jul 2009
    Amarillo
    Well it has the HVAC lines but all it does is blows cold air instead of hot air. The Ac doesn't work since there aint no compressor for the AC.
    Nov 2003
    indiana
    well i still wouldnt remove it IMO. a blower running is cooler than nothing in the summer!!!
    i would find a different spot for the battery!
    what year truck you have? if its a OBS truck why not just get a second battery box and stick it under the hood? thats where i got my second yellow top at.
    Jul 2009
    Amarillo
    well my burban was made in 1992
    Nov 2003
    indiana
    ok so just stick it under the hood ;) very easy and out of the way.
  17. #17
    May 2009
    san bernardino ca
    well why the second battery because you can buy a smaller battery.
    http://4xspower.com/
  18. #18
    Jul 2009
    Amarillo
    the second battery will be an auxuillery battery. I want to run dual batteries
  19. #19
    Nov 2003
    indiana
    ya dual batteries are better. WAY MORE reserve power!
  20. #20
    Jul 2009
    Amarillo
    yep. too bad i dont have the dual battery tray for my burban
