Results 1 to 12 of 12
CB/two way question
This is a discussion on CB/two way question within the Audio/Video Electronics forums, part of the General Discussion category; im looking for a radio, which i call a 2 way...but ive seen it called a cb...im really not greatly ...
    Registered User adamv7010's Avatar
    Nov 2008
    Mount Olive, NC USA
    CB/two way question
    im looking for a radio, which i call a 2 way...but ive seen it called a cb...im really not greatly informed on this style of communication so im hoping you guys can help.
    basically i want a CB AND a scanner in one....im thinking with a 2 way, with the police fire and ems channels programmed i can listen but im sure they're blocked for incoming contact from outside personnel.
    are there any radios available that would fit my desires?
    i would look myself and have been...im just kinda unclear on the radio i want and what its actually called..
    thanks in advanced
    2005 Crew Cab Z71- 6000k HID in lows and fogs, True dual exhaust,2.5" with exits past rear end.
    2005 Ext Cab Z71-T-bar crank, 295/70/17 Terra Grapplers,True dual exhaust, 2.5" pipe w/4" stainless rolled edge tips, 5% tint on all windows. HID Gate 8000k HIDS in lows and fogs
    Nov 2008
    Mount Olive, NC USA
    Re: CB/two way question
    up
    No room for my brilliance Honey Bear's Avatar
    Jun 2008
    Behind you!!!
    Not so sure you are going to find anything that will do both. You will have to buy a CB and a scanner.
    Quote Originally Posted by GreaseDog View Post
    you're a big paul bunyan lookin mutha fvcka.. i'd be scared to tell you not to pee in the middle of the back yard and not to leave your beer cans in the shower
    Nov 2008
    Mount Olive, NC USA
    knew a guy that had a midland something...he could hear the scanner freqs and could talk to people...but im thinking this was a 2 way...not on a cb band? does this sound right?
    Nov 2008
    Mount Olive, NC USA
    up
    www.Mudstruck.com Sport454's Avatar
    Oct 2007
    Double Wells, Arkansas
    Quote Originally Posted by adamv7010 View Post
    Yes you are probably right. In the 2m ham (Amateur Radio--license required) band and a little above the 2m frequency you could receive vhf public service traffic and still talk on the same radio to other ham radio operators. I am fairly up on communications by way of radio and I have never seen a scanner and CB all in one type radio.
    Nov 2008
    Mount Olive, NC USA
    the guy that has it has no license other than a drivers...lol
    he bought it from a mutual friend who works for a towing service...it came out of his personal truck...so im sure he was on the PS channels...
    its a midland...not sure of the model number..but the original owner replaced it with an icom
    Registered User eatinpavement's Avatar
    Jul 2002
    Lockport, LA
    there are scanners that will receive cb frequencies (27 MHz) as well as all other bands but receive only. anything other than citizen band (considered 27 MHz but is actually 26.965 - 27.405 MHz) you are required to have a license to transmit on.
    Oct 2007
    Quote Originally Posted by eatinpavement View Post
    Don't forget FRS frequncies. You are allowed to talk on these without a license but are restricted to using the handheld 1/2 watt radios.
    Information:FRS: 14 UHF frequencies for simplex operation. The frequencies are interstitial between the GMRS frequencies. CTCS may be used. Two kinds of use operation allowed. 1) Unlicensed operation on any channel using FRS type-certified radios. These are hand-held, ½ watt max, 2.5 KHz. deviation, with permanently attached rubber antenna. 2) Licensed operation on channels 1-7 by any GMRS license holder, 5 watts max, 5 KHz. deviation allowed, any antenna, using any equipment type-certified for GMRS. GMRS users may talk with unlicensed FRS users. GMRS users must transmit their GMRS call signs when using non-FRS type-certified equipment.
    Nov 2008
    Mount Olive, NC USA
    im freakin confused...i think i'll just find a cb and a scanner....
    No More Mr Niceguy xch3no2's Avatar
    Sep 2009
    Pacific NW
    Uniden bear tracker BCT7 or 8 will scan public safety (non-trunked) as well as AM CB channels. I have never seen a CB w/public safety/services scanning.
    89 K3500 RCLB- Fat Snarling RAT..Scat/Eagle/Crower/Crane/Edelbrock/MSD..TBI/EBL/TH400/Dana 60
    Nov 2008
    Mount Olive, NC USA
    thansk alot
    i will look into those
