Suscribed. Wanting to know exact same thing. I had been throwing around the idea of glassing them into the a-pillars, but not sure how that would sound as far as staging goes.
This is a discussion on 05 Silverado Component Installation Help within the Audio/Video Electronics forums, part of the General Discussion category; Hey guys I have an 05 silverado single cab, no onstar, bose or any of that just one speaker in ...
Hey guys I have an 05 silverado single cab, no onstar, bose or any of that just one speaker in the door one in the pillar behind your head. I am installing kicker ks6502.2 6-3/4" component speakers now here is the question. I am mounting the midrange in the door but where should I mount the tweeter? I've heard the dash, the pillar by the windsheild, in the door 6' away from the midrange. I wanna know what you guys think? I just want all around awesome sound. Thanks in advance guys!!
04' Silverado 2500 Crew Cab
6" Pro Comp Lift
35" Toyo M/Ts
18x10 Mazzi Hulks
I install them in the door where they came in the 99-02 chevs.
Same here I did mine in the door in the factory locations
Did you guys mount the speakers just like the factory ones or did you have to build a special baffle and then mount them to that?
1999 Silverado LS 4x4 Z71 w/ 5.3L
I use 4 tek screws and drill them into the door
Anyone have pictures?
2004 Silverado 2500HD 4X4, reg cab Long bed. 253000 miles
Thanks for the sig 454SS
There's nothing really to see in a pic, IIRC unclip the old speaker and housing, cut the wires close to the connector, solider the wires to the new speaker, stick it in the hole, self tap four screws into the door through the speaker mount holes done.
I timed the last truck...8 min for both doors including removing panels.
I work on alot of trucks.
When I redo mine im going to put mine in the factory tweeter location on the pillar. Thats where my bose ones are now
2006 white GMC sierra SLE crew cab, few mods, not much done at all
bagged 84 single cab swb
2001 mustang GT R.I.P.
6" Pro Comp Lift
35" Toyo M/Ts
18x10 Mazzi Hulks
Not much room at all. Very few tweeters that i know of will fit in there, the factory ones are real small.
The a-pillar tweeters will raise your soundstage but I prefer them closer to the driver, just sounds better imo
Thats what I thought. that'll be something else for chevyboy to consider. I had a rainbow 3way comp set in a 95, tweeters glassed into stock location and 6.5s and 4" mid glassed in the bottom of the door panel. Felt like the sound was all in the floorboard, and I didnt like it. Unless I stuck my head in the floorboard and it sounded great. Something else to think about.
6" Pro Comp Lift
35" Toyo M/Ts
18x10 Mazzi Hulks
OP-
Is your truck the work truck edition or does it have the factory component system with a separate tweeter above the midrange speaker?
-Cody
04 GMC
system in the works:
Also, are you staying with the stock HU? If so, the components really wont be that amazing unless you amp them. The wattage they need to perform well cant be provided by the stock radio.
i have to change out my inline fuse holder for my amps in a minute. When i do that ill go look and see how much room there is
