Results 1 to 10 of 10
simple question...HU Upgrade
This is a discussion on simple question...HU Upgrade within the Audio/Video Electronics forums, part of the General Discussion category; I have been looking around on the internet and have decided to replace the stock HU in my '98. I ...
    ... ReadyMix's Avatar
    Jan 2003
    Mississippi
    I have been looking around on the internet and have decided to replace the stock HU in my '98. I can't find any specific reference to weather or not the dimmer function will work on the Alpine HU's. I would like to be able to control the intensity of light without rewiring the brand new HU. Has anyone ever done this before. I am not too sure if the aftermarket HU's have connections and/or seperate circuts for this type of thing.
    1987 Chevy Longbed, SM465, NP208, 14 FF 4.56 Detroit, Dana 60 4.56 Detroit, 39.5" IROKs on HMMWV rims. NWF Crossover.
    WWW.BrokenTrucks.com
    YAAAAAaaaaaay FeeD's Avatar
    Sep 2001
    lockport, NY
    it may depend on the model but my alpine h/u dims when the lights are on. it doesn't fade like stock though... it's either bright or dim.
    04' sierra - coolride and slams up front, kp in the back
    Feb 2002
    Tulsa
    Most have a dimmer as far as I know.
    Jan 2003
    Mississippi
    FeeD,
    That is what i thought i would hear. I want to be able to adjust the brightness of the HU when i turn down the dash lights. There has to be a way. I would get aggervated driving at night and seeing the super bright HU lights in the middle of an otherwise nicely lit dash and gauge assy. Can anyone shed a little light on this.
    Jul 2002
    Portland, OR
    the new alpines have a wire in the harness for this purpose, you connect it to the dimmer switch in the truck. I just installed a 7893 in my boat and it had the illumination wire. obviously i did not use it in my boat.
    good luck
    '05 Chevy 2500 HD, LT, Crew, short-box, Duramax, Allison, Loaded.
    Jan 2003
    SoCal/AZ
    the illum. wire just makes the display either bright for daytiime then the parking lights are not on and dims at night or when the parking lights are on. there is not a way to control the brightness of your aftermarket stereo with your factory dimmer. sorry....
    eric
    2003 Silverado 4.8L 2wd
    2007 Avalanche 2wd FOR SALE
    Jan 2003
    Mississippi
    So on the aftermarket HU the illum wire needs to be connected to the dimmer switch, or the headlight wire?
    Want some? rollinstyle's Avatar
    Jul 2001
    Oklahoma City
    My Pioneer 840mp can be adjusted for brightness. It goes from 1 to 15.
    1996 Chevy Tahoe-2dr 2wd
    -Tint
    -Compustar 2-way paging alarm
    -Pioneer 850mp w/ 2 Pioneer 10" subs powered by a 900watt RF amp
    Sep 2001
    lockport, NY
    there is a factory dimmer wire in the harness it connects to
    Sir Smokes Alot
    Apr 2002
    Killafornia, La
    And whats dope about that pioneer is you can have the face closed for a clean look.
