Results 1 to 6 of 6
05 Reg cab
This is a discussion on 05 Reg cab within the Audio/Video Electronics forums, part of the General Discussion category; Lookin to upgrade the speakers in my sierra from the stockers (blew out 2 of them) have a Pioneer AVIC-D2 ...
    Oct 2009
    Bucks County, Pennsylvania
    05 Reg cab
    Lookin to upgrade the speakers in my sierra from the stockers (blew out 2 of them) have a Pioneer AVIC-D2 in the truck. 4 speakers total 6.75 in the doors and 4X6 in the rear. basically i'm just lookin to get some better quality speakers that have some bump to them, but clear enough to be able to hear the weather reports. No really lookin to add an amp but will if needed. Any help is greatly appreciated
    Thanks
    Kyle
    2005 GMC Sierra 1500 RCLB 4WD
    4.8L/auto
    Registered User 01xtreme's Avatar
    Jun 2009
    Bradenton, FL
    Re: 05 Reg cab
    You're going to have a hard time getting low end response from the 4x6's, but you can get decent response from 6.5's if you deaden the door, and also I prefer to use an mdf or birch speaker ring to mount the speaker to as well. As for speakers I am currently running arc audio speakers and have nothing but good things to say. I would recommend going and listening to some different speakers to help determine which type of sound you prefer.
    2002 Silverado RCSS 5.3L Whipple Supercharged (unfortunately bought the truck with it already installed using whipple's electronics)
    Stereo in progress All Arc Black series components, amplifiers and subs. Bit one processor custom console with subs and ipad 2.
    Oct 2009
    Re: 05 Reg cab
    spoke to a friend of mine who is good with this type of stuff and told him what i was shooting for and he recommended this to me:
    Rockford FosGate P1675 - in doors
    Rockford FosGate P1462 - in rear pillar
    Pioneer Ts-T110 - tweeters, he also recommended running an extra set of tweeters in the a pillar in addition to the set in the door
    does this all sound right?
    If i go with that setup will i need an amp to power all of this?
    Thanks,
    Kyle
    4.8L/auto
    Jun 2009
    Bradenton, FL
    If the tweeters have a capacitor inline, you can just run them in parallel off the speakers. If not, yes you would need a separate amp. I personally would avoid running extra tweeters on top of the ones already built in to your coaxial as this will drastically increase your high end performance giving you the impression of having less bass and midbass response.
    Oct 2009
    Re: 05 Reg cab
    Bought the P1675's and i'm wondering if the stock GM speakers had quick connect's on the back of them, if they dont, do i need to get gold plated connectors?
    4.8L/auto
    Jun 2009
    Bradenton, FL
    Re: 05 Reg cab
    you'll either need to buy speaker harnesses that will plug in to the factory GM plug and give you the femal spades you need for the speakers, or cut off the factory plus and just crimp on the spades. If you decide to cut the connector off, here are the wire colors to ensure you have correct polarity.
    Front Left: Tan + / Gray -
    Front Right: Light Green + / Dark Green -
    Rear Left: Brown + / Yellow -
    Rear Right: Dark Blue + / Light Blue -
