This is a discussion on Power cable through firewall within the Audio/Video Electronics forums, part of the General Discussion category; Can anyone tell me or possibly show me how to get a amplifiers power cable through the firewall?...
Is there anyway to get it through without drilling a hole? If not where do you get the two things in the picture
What size cable are you running and what truck are you working on?
You can get the step drill bit at most hardware stores and the grommets @ an auto parts shop, usually have a variety of sizes
4 gauge if thats what you mean. And a 2003 Chevy silverado 1500 ext cab
maybe someone will chime in if there is a hole in the firewall already, but i'm guessing you'd have to drill it.
alright thanks
hmm I wouldnt know about that for that truck. But i ran my powercable thru passenger side , I did drill thru the firewall. cant upload photos yet or i would show you.
There is a round flat spot on the drivers side firewall that looks like something was designed to go there. It is about 2" in diameter. Your truck may have something there but mine didn't. I ran several cables through it for emergency warning lights, 2 way radio power and coax cable. I will see if I can scrape up a picture of it when I am on my computer.
Build a man a fire and keep him warm for a day. Set a man on fire and keep him warm for life.
It's in the wrong place for a clutch pedal. It is actually to the left of the accelerator looking from the front. I won't say that it is not for a clutch, but I doubt that it is. It looks more like where a harness would pass through.
the guy who did my wiring wired it up through the door and under the hood and across the fender lip where it bolts onto side of truck (looking from top) and you couldnt even tell from outside or inside of truck unless door was open
current mods -
Cree reverse light bulbs
Candied tails
Blackbear Tune
Future
that not bad place as well.
Run it to the corner of the driver engine bay, down to the grommet that is between the door and frame. Cut a slit in the rubber and run the wire into the cab from there. Then you can pop off the trim pieces on the floor and route it all the way back to wherever you have the amps located. I have a 0 gauge wire plus two sets of 16 gauge wire ran through there so it's definitely big enough
This is a pic from Internet and is a rear door but shows the black hose in door jamb that I'm talking about
I just ran mine through a hole in the passenger side footwell...mine is a 93.
1993 K-Blazer Sport - Got it back!! Nice!
2005 Tahoe Z71 - For Sale
