Those dual players are horrid for noise.
Alternator wine is usually caused by a grounding issue. Try cleaning the ground on your battery, and move the ground for your amp around. Ive seen moving a ground 2" make a difference.
The problem lies within a ground loop being created between the deck and the factory amp of your truck, making sure all the grounds are good is a good start, sometimes moving them around will help.
Ive seen binders upon binders of the causes and fixes for this problem. Most of which are ground related.
LinkBack URL
About LinkBacks
