Results 1 to 17 of 17
Solo Baric in a EC?
This is a discussion on Solo Baric in a EC? within the Audio/Video Electronics forums, part of the General Discussion category; I have a kicker comp vr 10 in a q logic box now. I plan on upgrading the amp. But ...
    Mar 2002
    Los Altos, CA
    Solo Baric in a EC?
    I have a kicker comp vr 10 in a q logic box now. I plan on upgrading the amp. But i have a feeling that its not gonna put out what i want. Has anyone put a kicker solo baric in a truck box that fits under that back seat of a truck? I m looking to do just 1 sub. Any pics or advice is well appreciated. Are these subs power hungry? What kind of watts should i look at powering it with. I am looking at a 10" sub. What is the difference between a L7 and a L5. Thanks in advance.
    California Concepts TM 4" lift
    33x12.5x15 Goodyear mt/r on eagle 589's
    Flow 50 series
    K&N FIPK
    formerly justatahoe FSCparrothead's Avatar
    Apr 2002
    Cheyenne, Wy
    Loki has 2 in his and he says it hits. he will be in pismo this weekend with it for the meet try to make it.
    2003 Chevy Silverado 1500HD
    2004 GMC Savana
    2011 HD Street Glide
    In The Mud Loki's Avatar
    Aug 2001
    Eatonville, WA
    Well although i don't have 1 10 or even 1 12, i have 2 12" L7's in a largely ported box that utilizes the space that used to be my back seat. Now as far as the differance between the L5 and the L7, i've heard it, and it's there. my friend had 2 12" l5's in a similar box hitting pretty hard, but my setup was a bit harder hitting than that, and it was noticable. And my amp was only turned up less than half way while his was up over 3/4 of the way. The 10" L7 can handle 600watts RMS while as the 10" L5 can only handle 450 watts RMS now that's not max of course, because they are a bit underated, but close. For either application, i would say if you are doing a sealed enclosure, i would run 2, but you can make it sound good with one. I'm running a 1600 watt amp at less than half way with 2 12" L7's which are rated 150watts RMS higher then the 10" L7 and the draw isn't that bad without a cap and second battery, but i'm upgrading sometime soon. I'm going with a 220 amp alt dual battery setup and a 5.1 fd cap. If you want to see my sup enclosure here you go:
    good luck with your decision, and i'll try to answer any questions you may have to the best of my knowledge.
    Hope this helped.
    Jack
    2002 Chevy 8.1L 2500HD/5spd Allison - Tow Vehicle/DD
    1996 Chevy S10 Blazer - Wife's Ride
    1967 GMC K1500 350sbc 8" Lift 35's - Weekender
    1954 Chevy 6400 2Ton Flatbed - Restore project
    NEVER FORGET!
    Mar 2002
    Los Altos, CA
    I really like the idea of not having to remove the back seat. I especially like the whole entire "stealth" approach to systems. Loki yours is sweet, dont get me wrong. But as a college student I cant have that out in plain view. I know these subs really shine in large vented or ported enclosures. How will the sound in sealed enclosures? Would it be possible to make a larger sealed enclosure using the entire space under the back seat? I know that this will have to be "custom" made, so i know i m not gonna find it anywhere. thanks for all your help already
    Flow 50 series
    K&N FIPK
    Dirty, Baraka, "B" DirtyBlackHoe's Avatar
    Apr 2002
    Thomasville, GA
    Hey man I have a 1998 Extended cab Z-71 and I have 2 L5 10's under my back seat. They are in a sealed box with 1000 watts going to them. I love how they sound, how clean and loud that they get. I would definatley go with the L5's and get 10's because that is the biggest you will fit without having to raise the seat and other stuff.
    Mine
    2006 GMC Sierra SLT CCSB Z-71
    Wife's
    2004 Chevy Tahoe LT
    BB Tune|6K HID's|Spectre CAI|Painted front end|
    Aug 2001
    Eatonville, WA
    like dirty said, you can fit a couple, but if you just want one, i would build it to kickers sealed specs. you wouldn't need anymore than that. sealed enclosures are designed to operate at certain specifications that do not require a large amount of air space. just look on the kicker website or the leaflet that comes with the subs and it will tell you how much room you will need and basically how to build the box. want my opinion build a 3 part sealed enclosure, leave room for the amp in the middle and throw 2 10's under that seat...thats just me, or you could gut out the bottom of your seat and turn it into an amp rack...there's a lot you can do to keep it stealth, you could gut out the back of the seat somewhat and put the subs on the back wall and put the seat over it, but i would shave the shag and make sure there's at least an inch off the top of the amps, and make sure they are cooled...
    NEVER FORGET!
    Apr 2002
    Cheyenne, Wy
    Originally posted by Loki
    Well although i don't have 1 10 or even 1 12, i have 2 12" L7's in a largely ported box that utilizes the space that used to be my back seat. Now as far as the differance between the L5 and the L7, i've heard it, and it's there. my friend had 2 12" l5's in a similar box hitting pretty hard, but my setup was a bit harder hitting than that, and it was noticable. And my amp was only turned up less than half way while his was up over 3/4 of the way. The 10" L7 can handle 600watts RMS while as the 10" L5 can only handle 450 watts RMS now that's not max of course, because they are a bit underated, but close. For either application, i would say if you are doing a sealed enclosure, i would run 2, but you can make it sound good with one. I'm running a 1600 watt amp at less than half way with 2 12" L7's which are rated 150watts RMS higher then the 10" L7 and the draw isn't that bad without a cap and second battery, but i'm upgrading sometime soon. I'm going with a 220 amp alt dual battery setup and a 5.1 fd cap. good luck with your decision, and i'll try to answer any questions you may have to the best of my knowledge.
    Hope this helped.
    Jack
    Jack i think the reason your so happy with yours would be couse of the designer of the box did such a great job
    2004 GMC Savana
    Aug 2001
    Eatonville, WA
    well...what can i say...now design me a fiberglass enclosure
    NEVER FORGET!
    Apr 2002
    Cheyenne, Wy
    Now that your in California we might be able to do that
    2004 GMC Savana
    Aug 2001
    Eatonville, WA
    well lets get crackin mister wizzard, all i have is time, hey can i borrow a quarter bro
    NEVER FORGET!
    Apr 2002
    Cheyenne, Wy
    i will take a look at it tommorow, but i dont have much time!!
    As far as the quart goes, i might have to sell a kidney first so give a few months.
    2004 GMC Savana
    Aug 2001
    Eatonville, WA
    well you know i'm a part time college student in need of book money, i'll take it out, leave you in left over beer ice and sell it for you on the black market. I'll just take a quarter and get the rest back to you
    NEVER FORGET!
    Apr 2002
    Cheyenne, Wy
    might get more on ebay!!!!!!!
    2004 GMC Savana
    El Tiburón (formerly shark_g) Tiburon's Avatar
    Feb 2002
    Edinburg, TX
    Man.. Loki, I bet you rattle your neighbors windows with that set up.
    02 SCSB Sierra with a cup holder
    01 ECSB Sierra my fiance's truck
    Both are indigo blue step side.
    Sand Inspired Kustomz Code3Response's Avatar
    Jun 2003
    San Luis Obispo, CA
    Shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiittttttttttttttt tttt. I checked out Lokis truck today - whoa. We were guessing about 145 db or so. It was insane.
    08 Chevy DMax CCSB 4x4 LTZ: F'in Fast
    05 Chevy DMax CCSB 4x4 LT Sold
    00 Chevy Tahoe W/ 05HD Front End 15"FTS 40s/22s
    formerly sr2003 1Down5Up's Avatar
    Aug 2002
    Delaware
    Just curious, is it possible to 2 12" L7's in a standard cab truck? My seat is already moved forward for my Alpines, and I refuse to get any closer then I already am.
    Steve
    2007 Chevrolet Silverado Z71 4WD Ext Cab
  17. #17
    Aug 2001
    Eatonville, WA
    Steve
    not sure about the 12's, but i know the 10's will FORacing has 2 of them in his rcsb i saw that this weekend. just depending on how far back you need to sit i'm sure, i wouldn't think you would be too comfortable, but it may be possible not sure though
    NEVER FORGET!
